Hi Peter, Maybe start another thread and make it a poll :yes:
Something like "How long did your engine rebuild take"
Options:
3 Months or less
6 Months
9 months
12 Months
Greater than 12 months !
I for one would be interested in the results.
Maybe in the comments SAUérs could add
Which shop and were they totally happy with service
Did it come in on Time and Quoted price ...... LMFAO
(allowing for owners that add/change bits as they usually do making cost go up)
:action-smiley-069:
Many workshops are like builders - they don't like turning down work so they agree to do your job even though they are busy. And of course the best shops are always busy. The hard bit is priority - regular customers and mates probably get priority. Also I think regular calls for updates are in order...and often necessary!
Here we are 5 weeks since I put my car in for the work and it sits there getting a nice coat of dust,haha :yes:
The Fn block is still not ready !
I believe this is a normal situation in the world of Mods, don't like it very much :angry:
14months (edit: and counting.) in one shop for the same thing, 3months before it was touched.
I waited 5 weeks as nitto was out of stock. Then another 8 weeks waiting on machiner. Bottom end finally assembled. Now most likely another 5 weeks for head to be finished. Then most likely another 5 weeks to put motor back in and tune ?
So will be close to 6 months fkn
I have one thin going for me, I had all of the parts delivered 3 months ago, so there is NO waiting on parts, or saying they are waiting on parts. I have also had other work done by them and they were on time both times, so?
Thanks anyway for getting me ready for a lot of bullshit from them as I live too far away to just pop in to see what is happening, so I can only live in hope :(
Options:
3 Months or less
6 Months
9 months
12 Months
:action-smiley-069:
Haha, that would be too hard to read while I have my cay in there, I am not good at waiting for anything, I would buy the second best if I could not get my first choice ASAP, so even the 5 weeks has seemed, like forever :(
I have read a lot of builds on these sites, had to stop after I put my car in and starting to understand I was getting the mushroom treatment and it was giving me the shits, I have way too much time on my hands to play the waiting game.
It will be interesting to see what happens over the next 3 weeks, that was the latest finish time given to me, 6-8 weeks ????
Haha Paul it will all be worth it ?
Response and torque monster
Can you imagine , the car has the response/torque and Paul the monster, what a combo, ZZZZOOOOOOOMMMMM! :)
Haha!!! Ah a while ago, Pete said it shouldn't take any longer than 6 weeks. Yeah right :D.
Farken mushroom factory industry it is.
Get it right, 6 to 8 weeks was the quote, just because nothing has been done in 5 weeks and off you go getting all negative , have faith Piggaz have faith :)
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
