Its really not a valid question on its own and even my first reply was wrong. The amount of boost has nothing to do with valve springs etc . The real questions are how much power and how many revs and to what use is the engine being put?
The amount of boost does relate to valve springs as the boost pressure is working against the inlet valve, but there's way more to worry about before that.
Maybe op is talking about tyre pressure?
you could probably hold 35psi with your thumb.
Yes it does have to do with valve srings as mentioned above, but I think what everyone is getting at, is there is way more things to do than just list whats needed to run 35psi. Sounds like you want people to do the home work for you. I have never met someone that just told what to do, and people just run out and do it. There would be some kind of human intervention on your part.
Next time start out by simply spending time list what you have at the moment parts mods and go from there. Or you will just get simply answers mate.
Most people I know associate boost with speed or power. Hmm. A friend of a friend of mine had a dodge neon just as he learned how a waste gate worked he cranked the boost to 30 psi and now walks to work. Once in a while I give him a ride if im heading that way. And all.he tells me is "man that car was crazy at 30 psi." I wounder even today if he learned anything.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
