Its really not a valid question on its own and even my first reply was wrong. The amount of boost has nothing to do with valve springs etc . The real questions are how much power and how many revs and to what use is the engine being put?
The amount of boost does relate to valve springs as the boost pressure is working against the inlet valve, but there's way more to worry about before that.
Maybe op is talking about tyre pressure?
you could probably hold 35psi with your thumb.
Yes it does have to do with valve srings as mentioned above, but I think what everyone is getting at, is there is way more things to do than just list whats needed to run 35psi. Sounds like you want people to do the home work for you. I have never met someone that just told what to do, and people just run out and do it. There would be some kind of human intervention on your part.
Next time start out by simply spending time list what you have at the moment parts mods and go from there. Or you will just get simply answers mate.
Most people I know associate boost with speed or power. Hmm. A friend of a friend of mine had a dodge neon just as he learned how a waste gate worked he cranked the boost to 30 psi and now walks to work. Once in a while I give him a ride if im heading that way. And all.he tells me is "man that car was crazy at 30 psi." I wounder even today if he learned anything.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
