Fuel set up:
Factory HICAS hard lines
1150cc Bosch injectors (stainless steel internals)
3L surge tank (anodised)
Holley Dominator 1400 fuel pump (ss internals)
Holley FPR
Earls 175 GPH fuel filter
Cost = $2k
+ in tank pump
Thanks mate. Will get a quote
I think issue comes with time...I've been put onto this to help counter the breakdown/corrosion/gumming
http://lucasoil.com/products/fuel-treatments/safeguard-ethanol-fuel-conditioner-with-stabilizers
Haven't heard that...anyone had any experience with this?
well as soon as I have issues I will let you know but so far so good.
Having said I've put 98 in it for now.
When I put E85 this is the lubricant I put in to help the protect the engine
Smells awesome too
Smells awesome too
Thanks Anthony, great input as always, appreciate it.
On another note, quick question re front pipes:
Does anyone do a 2 x 2.75in into 3.5in front pipe??
HKS do 2 x 2.75in into 3.35in which is pretty fkn annoying :verymad:
  • Like 1
Midori Seibi do front pipes 2 x 2.75 to 3.54 (90mm) if that helps
available in stainless or Ti (I am looking at the 90mm Ti myself)
http://www.perfectrun.jp/src/detail.php?pid=201002&pname=SUS%20FRONT%20PIPE&maker=MIDORI%20SEIBI&maker_id=201&result_mode=pmk
Thanks again!! Don't know how I missed that one ;)
Mmmm the HKS one is about $160 cheaper compared to Midori Seibi.........
Do you currently have the ss Midori? I would be interested in it if you are going to upgrade to TI....
Fuel system set up is now ordered. Went through Julian @ Aftermarket Industries. Very helpful and from what I've heard very high quality products, should arrive after Christmas!
nah. I have Ti bro.
I would suggest also getting an aftermarket front diff when you put it in... The system munches standard ones :(
  • Like 1
Thanks for the heads up Simon, appreciate it. Are you running it or have just heard of a few cases?
I have never had a front diff failure...has anyone out there had first hand experience with this? I'm wondering how much damage is done when they fail....?
If just strips or munches the diff gears and makes bad noises then I can live with that but if it's going to destroy the sump/diff housing as well that's a different story!! It would be dump not to upgrade while the motor is out now and save the heartache!
I see JustJap have the Quaife diff on their website for $1,800 which is no doubt not cheap...
http://justjap.com/quaife-atb-helical-lsd-front-differential-nissan-skyline-gtr.html
Who has purchased one of the above and where was the best deal??
Bit of an update below:
Head off and will continue stripping
Sump off and getting cleaned up for extension
Final clean to do then acid wash
I've personally done 2 front diffs in the last year. I'm lucky they have just died but it's not uncommon that they can punch out of housing and take out the sump.
I would suggest a Quaife or go a Ruzic diff controller if you want to keep the stocker
Edited by SimonR32
what diff you put in Simon?
Quaife is by far the better option imo
Looking good, I have seen a few fail on the race cars, one ripped the diff housing off the sump :(
I got my Quaife from Palmsdale NZ, wasn't $1800 :)
If you are taking the valves out, get a spark plug socket with the magnet inside, sit it square on the retainer and give it a good quick hit with a hammer :D
  • Like 1
funny you mention buying a quaife diff from Palmsdale as I got a quote from them and is costing $1700 postage not included
Sourced my quaife diff from power tune Australia cost me 1500 delivered
  • Like 1
  • 3 weeks later...
    • I've searched fairly extensively among Japanese websites but found nothing really like those skirts in your photo. The closest I got was Origin Labo side skirts however they look more 'complete' in that they have a finishing piece or tab at the rear of the skirt so it blends into the bodywork, unlike the one in your pic. For that reason I'd say the skirts in your pic could be adapted from another car and they didn't include that tab piece, or those skirts aren't copied from an existing skirt but an original design. Sorry I can't help out in regard to ID'ing/sourcing them
    • Wonder if JB Weld sponsored the event lol
    • There's a big difference between a car built with millions of dollars in R&D, and someone like yourself taking a normal sporty road car, and making it 5 times more powerful. At the same time, get a modern sports car, and you can turn them up towards the 1000hp mark a lot easier too. Also, give that Lambo another 20 odd runs, and chances are it too may break something.
    • There isn’t really a cheap upgrade here. If someone made a decent, bolt in 6 speed that holds some grunt, it would do very well. The 5 speeds suck. You can put a - OSG 5 speed gear set into it. Ratios are tall so it zaps the “zing” out of it. Had one, busted it. - PPG 5 speed gear set synchro or dog’s. Ratios are even taller. - An overpriced Getrag. Nice to drive, expensive to source now. - A sequential of some sort. Expensive, very expensive. How many times do you pop a 5 speed before you throw the toys out of the cot?
    • Yes, fair call. I don't have any special love for super/hyper cars but it was impressive to watch the Lambo line up against successive skylines without any problem at all.
