So to add another view:
Used PFC $800
New Haltech $1800
Dirty 30 + pistons + rods and hone $2k
Hypothetical, if you can do all the work yourself bar the hone.
5hp for the haltech (if that) Vs 15% tq min for the RB30
It's not about the extra hp, it's the features and how much nicer it drives
It's like comparing a 500hp HQ and a 500hp VF commodore I know which one I'd rather drive every day
  • Like 2
Used PFC $800
New Haltech $1800
Andrew Hawkins R32 gained 20+ awkw just from changing to a haltech. And as previously said its not just about peak power it allows closer and more accurate reading of things like knock which means you can add more timing and boost. It also has much better drivability on the road.
Having said all of this you'll never know the difference until you actually try it. I love my haltech and I'd never go back
Used PFC $800
New Haltech $1800
This is what scares me when I think about the money I have just spent on new turbo, manifold and now ECU to come
just doing the maths on the changeover from pfc to haltech, lot of coin
$3k for supply fit and tune ecu for flex fuel
walbro e85 pump supply/fit $400
flex sensor supply/fit $470
external 4bar map sensor supply/fit $250
E85 fuel & flush $200
optional:
oil pressure sensor supply/fit $330
optional:
Agreed, this was my quote:
Haltech Platinum Pro ECU (rrp is $1995)
Installation of Haltech $125
S&F E85 Sensor and Haltech I/O12 expander module (required to get the sensor to talk to the Platinum Pro) $1095 fitted
3 Port boost solenoid, supply and wire up to haltech and setup $350
Tune Haltech on 98 octane $800 (normally $1000)
Tune Haltech on e85 $800 (normally $1000)
$5,165 including tune....wtf
Quote is from a major brisbane tuning company
6C859AB6-5CA1-436B-AA65-873DBAD76007_zps
Without crank trigger
31EDDFD0-69B7-4BD8-8267-31B5B0438C21_zps
With crank trigger.
I can't remember now if the without crank trigger was done on the FC or the Link G4, it's been a few years since I put that on. Either way, that timing variation with the timing taken from the CAS is woeful at best.
Both graphs taken from my own car.
Yep it's not good. This is the issue with a newer/faster ECU mating to old tech/speed of the CAS however.
Using like for like (PFC/CAS), PFC isn't actually seeing said variation... So you aren't actually having a problem with timing.
There is no peak to be gained.
As much about dyno variance and a tuner putting in a bit more time than anything else.
To answer your original question, outright power wont change, tuned exactly the same peak power and tq is governed by engine spec, condition etc.
Everything before peak power the difference can be minimal to 20hp in certain areas (although very rare). The newer ecu's have some compensation tables which help with drivability. 5Hp is noticeable to most in off boost power
Then it comes down to features, pay more you get more. If you hardly use them, your paying for wank factor. If you compete with your car and have a dog box or better, launch and flat change will be worth it. On a street car you will eat syncros if used often. So start going to the gym now so you can do a gearbox R/R by yourself.
The only time more map resolution is of benefit is when you have something funky going on- more common on NA engines with harmonics. The director of a large ECU company told me many years ago that they can do 100x100, but its just time entering zones repeatedly and at a starting price of $120 per hour for tuning it will add up.
On the street (and forums or even friends too) there is a lot of "you should" this and that and in a perfect world where money/time, car off the road is no object, sure! For this reason, anyone who asks about my car, its stock with an exhaust and im happy with it, I don't have to listen to their BS or questions.
If it was me, I would use the PFC and go from there. Why? Because I know guys who can map one from initialize to done in less then an hour which includes a lot of drivability and economy stuff. Sit it overnight for cold start and its done. Then go from there
Best post in this thread.
For me the deciding factor comes down to the need (or not) of auxiliary/extra inputs. AUX for things things like a E85 flex-fuel tune and so on. If you don't plan on that, then there is not a lot of benefit to spending $1500+ on the change over.
New ECU & inputs etc - $1800 - $2200
Tuning - $600+
Minus resale of PFC - $600
Leaves around $1500-$1800 depending. IF you wanted E85/Flex (or things like launch control, oil temp/pressure ECU cut out), it is total no brainer - change the ECU 100%.
We all had the powerfc and that was the cause, even piggaz who got brand new nismo afms had the *cough* no dry solder there
Interestingly my PFC Pro never had that issue.
My original PFC did, but it was once every 3-4 months (and I drove daily). Hell my current car, 18 months old, has more coughing/shit bugs
same here, running PFC Pro at the moment, never had any hiccup
Cmon man, Andrew Hawkins.
I wouldn't be so sure with that, man. Terry had huge timing issues on his blue R34 GTR (PFC) years ago.
I may be wrong but I'm sure my 34 with PFC has Z32 afm and 2 map sensors? I know 1 sensor is used for the boost gauge but why would my PFC be seeing both afm and map?
Seeing it and using it are two different things. It may be used for boost control but not for fuel and ignition.
The factory R34 ECU uses AFM for steady-state and MAP for transient throttle.
The nicer it drives on partial throttle is from the extra power and trims the later ecus have. Point being, dollar for dollar if you can do everything yourself the long block option shits all over a going to a haltech from a pfc, way more off boost torque and power and pretty much 1000rpm less boost threshold.
So many variables, like mentioned and in addition
the willingness of one tuner to push it harder
and another being more conservative.
If he used the same tuner and dyno something had to be wrong with it
mechanically or electronically.
Its common for people to go from a factory ECU to a pfc and gain 15kw minimum, are you suggesting that going from a factory ECU to a haltech with no other changes nets 35kw? Ludicrous
Full power is dictated by the engine spec, condition and state of tune. In this day and age and even for the past 10 years 99% of aftermarket ECU's will run engines to their full power potential.
I do actually know what the difference is, while I haven't used a haltech, I have gone from stock ecu, to power fc, back to stock but flashed. Granted it wasn't on a GTR but the results are still indicative. and FYI there wasn't a lot of difference between the M800 and flashed stock ecu in terms of drivability.
Don't get me wrong, a better ECU is nice, but for a lot of people there are not the number 1 priority if they already have a PFC
That would be like having a garrett GT series turbo, then upgrading to an EFR because they can spool a little earlier.
Not the best analogy, ok it would be like going from a strong single plate which is rated to hold more tq then what you have and upgrading to a nismo twin plate because it drives nicer and can hold a bit more tq. But at a cost of 3x of what you currently have, which is holding up fine.
  • Like 1
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
