A lug nut or wheel nut is a fastener, specifically a nut, used to secure a wheel on a vehicle. Typically, lug nuts are found onautomobiles, trucks (lorries), and other large vehicles utilizing rubber tires.
Jdm - Japanese Domestic Market
Don't know if this helps mate I used arp studs on my gtr. I bought the wrx kit for the front and rears. Fronts pressed straight in. the rear was a bit tighter to press in so a light file to help them go in all was needed and used Advan steel lug nuts open end.
The reason for them being "A bit tight" was because the fronts and rears are different. Fronts are a 14.3mm (0.565") knurl (ie as per Subaru) and the rears are 13mm.
And nothing wrong with ALU, just torque them to spec.......
that's not really my experience. I never had a failure or one come off but I was not happy with the wear on the flange where they seat on the wheels or the fact that they didn't always hold at the torque they were set to. I've been a lot happier since I changed back to steel
  • Like 1
Rays Duralumin lug nuts look tasty...
weight reduction ftw.
100g of weight saving so close to the hub center is not worth didly squat.
My Rays Duralium nuts used to come loose constantly when torqued to spec. Think of the weight you'll save when a wheel comes off! :)
Cheap nasty steel wheelnuts are the way to go.
Was going to drill out the rear hub but the hardened steel makes mince meat if drill buts so just went Nismo studs on the rear. Lol turned down the end so they are quick start like ARP and dropped off to zinc coaters with other bolts ... Overkill is my middle name :)
I ended up getting all the arp studs for cheaper than a rear set of nismo ones, good old gtr tax!
Edited by just32gtr
Yeah that's why I originally bought them because of the close sizing match
I got lock lug nuts and got a special tool to unlock. but it fits on and is only about 10-15cm long. can someone tell me what tool to use to loosen them. I need something with a long lever so i don't think pliers will work :/
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
