What Have I Done?
RB25_Zenki
 Share
So let's get this straight. You're not swapping cam caps. You've only moved the splash guards?
If so, great. Drop your oil, fish through it like the boys have said. Buy yourself a supermagnet sump plug while you've got the original one in your hand and are down at SuperBarn buying new oil and a filter.
Just get a new one and put it back together, even if it is in the engine and manages to make its way to the sump the gause over the oil pick up will stop it getting into the oil pump
You will most likely find it one day, I once found a 13mm ring open ended in my BOV return pipe lol
  • Like 1
Did you do what I said? Honestly every nut and bolt I have dropped has fallen into the splash guards and slid into a nook where a magnet would not get it. Also if you can, roll the car back and check the ground
 Share
