Everyone loves a picture.
Timing logs off my own car.
Without a crank trigger.
6C859AB6-5CA1-436B-AA65-873DBAD76007_zps
With crank trigger.
31EDDFD0-69B7-4BD8-8267-31B5B0438C21_zps
Probably worth mentioning that it's not essential on all RBs. For instance mine with the stock CAS is about as accurate as your trigger set up
I don't understand how some can have issues while others won't, even with the same setups, .. I want to upgrade ECU but am fearful of timing issues, so don't know if I should go for a trigger kit from the get go even though as you say it's not essential in all cases
I hope something like that with all the mass at one side would not cause issues at high rpm? The design is a little different than the others I have seen. Would it still work with vct?
Edited by BlackBox
Hi,
I thought the same but then I looked at some other kits that just use a longer bolt in the position of the adjustment bolts on the cam gear which weighs about the same as this 1.6mm rolled steel.
I welcome professional feedback :)
Cheers
The issue with using a disc is the centre if the cam gear is set back from the front.
Not a problem. Two piece centre, with a shim/washer behind. Spot weld together if paranoid, or make it out of 3mm sheet instead and machine some thickness off the bent up arms afterward.
The 2mm gap is the detection range and the finger needs to within the 2mm
This is what I was talking about, mine on my setup didn't read correctly till we got it out to exactly 2mm, any less and it would miss teeth, @ 1.1mm it would miss upto 9 in a roll at cranking speed, my ECU has a built in oscilloscope and that is how we found this issue
You only having one finger to look for probably won't be an issue though
It isn't volume it needs to be same moment of inertia. I=m x r x r where m is the mass in question and r the radius of the centre of the mass.
To work it out treat the bent up tab as one piece and the other section as a second piece. Add the results together.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
