What pricing are you looking at and what will be included in the kit/what will have to be sourced?
Part of me is really keen, but then another part of me thinks I should save the time/money and live with stock as im not having any issues. Too hard to make decisions on this car sometimes lol
It's looking like about $300 for all the mounts and cam trigger wheel.
I can source the sensors also for $70 each and you will just need to get the balancer modified at any machine shop.
I still think its the optical pickups in the cas that are the problems, because even with a 24/1 aem trigger disc i still saw issues, when we hacked up the cas with a hall effect pick up with 24/1 set up, had no problem.
I thinks its a reasonable conclusion to draw, and to solve the problem any hall effect setup off the crank or even a cam only hall effect trigger will work.
I have never seen a hall effect trigger system not work.
How would you go about a cam only Hall effects trigger?
That sounds like the cheaper/easier alternative if it is the optical sensor that is the problem and not the absence of a crank sensor
You could do a cam only hall effect trigger easily enough. You would need 2 sensors and two chopper discs. One disc would only have the single trigger, and the other might have 6 or 12 or 24 depending on what you think you can make worth with the sensor and the ECU. The sensors would probably end up being mounted axially (rather than radially like in Murray's current design so you could have one trigger wheel inside the other. Or you might have one radial and one axial perhaps.
I get sensors from www.digikey.com.au
They are the cheapest supplier I have been able to find in case anyone is looking at hall effect sensors of the Honeywell 1gt101dc type and other brands too. They also have pressure transducers in various types and pressure ranges, once again in Honeywell brand.
That may help people who are looking for automotive sensors :)
wow! that's changed since I last bought some. The last batch I got of them they were only about $35 each!
Well ignore that then!
RS prices have come down too. They use to be about $80 a sensor.
Edited by r33_racer
Well guys ive had alot of trouble in the past two weeks getting in contact with the factory in china and as far as I know tthe first batch still has not shipped.
I'll keep you all updated
Super Keen you are BlackBox!
Certainly... anything is possible, I would need to see if there is a dual pickup hal effect sensor or similar more compact items as having two units next to each other will get bulky.
Lets just say I've wanted to fly to china to have some stern words with a few people.
I've been talking to the factory up until 2½ weeks ago where they stopped all communications, I ended up contacting the company register in HongKong to obtain the business owners details to contact them and finally heard back last night from one of their sales girls who informed me they are being re-made as there was a problem with the finish and they have been trying to hide it from her by not answering me on Skype, Email, Phone or WeChat...
The business owner has promised me that they will ship this week..... this is all I know and I've well out of pocket at this stage so my fingers and toes have been crossed for weeks they actually show up!
If that fails, contact Julian at Aftermarket Industries / CNC Industries. Apart from making good fuel systems he also has very decent CNC machining capability in China. He made the first 3 alloy spacer plates for my V3 engines and the quality is great.
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
