  • 3 months later...
  • 1 month later...
Hi everyone,
I'm soon to get a set of these made for myself locally and was wondering if anyone else is interested? Can do individual parts but would ideally have between 3-5 people interested. Cost wise its looking to be around $550 a set ( price will be confirmed though when there are definite numbers) I know the price is significantly more than the original run but it would still come in being sub $800 on the car and running while most other kits are $1000+. More than anything it highlights how much effort Cameron went into originally to get this organised for everyone at the best price he could! I have adjusted the original files slightly to suit easier to get fasteners which seemed to be a small issue originally but other than that really they are as Cameron designed. Please pm me or post here if you are interested and I can get the ball rolling.
Thanks,
Nic
  • 11 months later...
hi guys sorry to dig up and old post but i dont suppose anybody has the file for the crank trigger bracket, im currently converting over to a link ecu and would like to use a trigger system and i fancy building my own rather than paying the mental prices out there
thanks mike
  • 6 months later...
Anyone have one of these kits for sale or have the CAD files that were in a dropbox link posted a couple of times (the link no longer works unfortunately)
I didn't know anything about crank trigger setups at the time and now looking back this was an excellent product at a great price point and kicking myself for not jumping on it when murray was still selling the kits.
Thanks!
All good thanks for your help mate, legend!
Will keep everyone in here updated as to how i get on. If there is more interest i have access to a CNC so could get another group purchase going again.
  • Like 1
  • 6 months later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
