Cheers mate. Was working on it every day from about mid October to Xmas but the motors has been a long process maybe 2 years we used lots of non off the shelf bits which took awhile to complete and I wasn't in a hurry because the car wasn't done anyway. Hopefully around 2months fingers crossed ready for tuning.
I am newish to all of this and think you blokes have great patients, I am struggling to handle 4 months of being treated like a mushroom ,lol
Guess when you are hands on it is more personal and interesting and time just gets eaten up.
I get impatient waiting for other blokes builds to be finished :)
What you need to do then is buy yourself a second one incase of this type of situation haha :cheers:
Cheers. It's actually a Mazda 6 colour. When in the sun it's quite a bit lighter in person.
Had 2 300ZXs, one was red the other more maroon and that was a better colour for that car..
I think it is David that has a red R and looks amazing a well :)
Said I would never have a black car, but have one, looks great just cleaned, but give it 10 minutes :( ,LOL
  • Like 1
  • 2 months later...
  • 3 weeks later...
Checking bulk head connectors facing correct directions.
Rips gearbox adaptor plate and engine mounts back from HPC
Ran the fuel line through the rail to keep clear of the exhaust, driveshaft and to keep the line straight as possible to hit the mechanical pump at the right height.
New chopper wheel fitted to tailshaft.
Unfinished bracket to mount the new tailshaft sensor.
Auto trans outlet temp sensor.
  • Like 1
Hey guys,
I have a ton of pics so ill keep them coming as i can.
Converting to manually operated windows. Mixture of Daihatsu applause and gtr mechs did the job.
Great build mate,,,loving it actually.
I have a question for you,,,can you shed some light on how you did the window winder conversation?. I also need to do this and any help would be much appreciated.
Cheers
Neil.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
