were they the ones for sale for ages out of a 33?
they look good
yeah they were up in the SA for sale thread a while ago.
They are heaps comfy and hold me in very well even though they are reclinables.
Genuine stuff is so expensive, can't imagine buying the new :blink:
A side effect with them on the super low bride rails is my shoulder now sits below the window line haha... makes traffic driving a bit more challenging
yeah mine is the same, its good to have headroom and legroom again though.
The headroom wasnt ever an issue for me haha im not that tall :glare:.
the extra leg room between the wheel on the other hand is fantastic
love the headlights! lol wish i had the skills to do it!
haha it was my first time doing anything like that. just take your time and its now harder than fitting a gearbox/turbo/brakes.
and the light output is well worth it. Definitely one of the best mods i have done for drive-ability
  • Like 1
Car was not getting up to temp and dropping way too cold when cruising at higher speeds so i figured something was up with the thermostat.
yup there is your problem.
11780480_10154168556389896_328912441_n_z
plus the gunge
11777937_10154168556434896_1023904943_n_
11793139_10154168556439896_513145175_n_z
Awesome thread man! & nice looking 32. I had a 4 door myself, which I put a genuine gtr front end on.post-132714-14380752785081_thumb.jpgthis pic was taken after driving it home from the panel shop! post-132714-1438075345046_thumb.jpgthis wasn't even 12hrs later! Chuck pulled out in front of me, bent chassis. Car was written off, was not happy[emoji26]. But have another one now, and I'm currently putting all the parts i salvaged off the old one, minus gtr front end.post-132714-14380755211665_thumb.jpgkeep up the good work, eager to see how it turns out.
Awesome thread man! & nice looking 32. I had a 4 door myself, which I put a genuine gtr front end on...... But have another one now, and I'm currently putting all the parts i salvaged off the old one, .....keep up the good work, eager to see how it turns out.
Thanks man i am glad you enjoyed the read. very sad to hear about the other car. i had visions that would happen to mine on the drive home with the GTR front end.
do you have a build thread for the new one?
i too had the gunge.
did you do a chemical flush of the system or anything, was there much else in there, my waterpump was also a bit gunged.
yeah i ran a flush through but i did do that when i changed the radiator back when i got it so not much came out. mainly just around the thermostat
Wasnt this car on episode 5 of lend us a ride?
haha fantastic memory! i was there back when it had the type m front.
https://youtu.be/j0CCIL4oFho?t=166go to 2:45
dont have a thread yet, but got plenty of pics & the rest of the parts are going on next week. Been meaning to do one just got to get the time to sit down and write it up!
Nice, did you talk to Marty and Moog?
yeah i had a quick chat to them during the meet
sounds good i will keep an eye out for it
  • 5 weeks later...
The end of an era :unhappy:
shit happens.
based of the data my DVR/dash came collected 47km in an 80km zone through an unsigned(no yellow speed sign) corner. rocks/mud/sticks all over the road resulting in a very anticlimactic crash and the damage you see below.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
