That sucks man! I think ianmack79 jynx'd you with his post above!!
Unfortunate to see a clean Skyline take a hit like such, what do plan to do?
the crash happened on 01/08/15. took from then until 25/08/15 with insurance company before an end result was settled.
got quote for repair, Just Car decided they wouldn't fix the car (but they are not writing it off) due to any repairs made would be unwarrantable (their reasoning was my cars paint condition and the extensive custom modifications done to the car...)
final result is i get a cash settlement for the value of the repair quote (less my excess and any admin fees). keep the car with rego and i fix it myself.
Noooooo! Devastating to see this! I know how your feeling, hope I didn't jinx you like the post above says. Hopefully the damage isn't too bad.
apart from the obvious cosmetic/panel damage it was to bad. snapped caster arm, bent LCA, bent engine crossmember, rad support, intercooler and piping. etc
Shit mate.
You going to repair?
i have done most of the repairs myself already or at least bought parts needed. it will never be what it was. plan is fix it enough to be 'presentable' on the street but no go all out with whole new GTR front end/fresh paint.
street/track the car then probably sell it or part it out. see how we go...
11952998_10154262410289896_6082621894529
Edited by CRSKmD
Everything is fixable - just depends on how much kesh you want to throw on it.
It's looking heaps better.
Yeah trying to keep it on the cheap to fix. Leaving at a point where if I want I can part it out and get some of my money back out of it haha
yeah been through that too, i swapped out a reo, front bar/lip, n1 headlights... those N1's werent cheap
Yeah it's no fun. Already bought headlights, guard, indicator, reo, cooler and piping, caster arms, LCAs, cross member and probably more to come
My lights have about $700 put into them on top of the price of the lights them self... :/
  • 4 weeks later...
Started to work more on the car today. internet has been slow and dropping in and out, this worked as good reason for me to get off my ass and do something on the car.
12083863_10154353900174896_1368638387_n_
pulled the stock seats out and gave the interior a clean and put the brides back in.
12071391_10154353900339896_831758007_n_z
rear seats still need a clean and to go back in but snapped this semi-stripped interior photo (because racecar?)
12063769_10154353684019896_4010418957050
12042079_10154353900124896_534569328_n_z
Headlights also are in progress to being back to how they were but added wank
12071806_10154353900139896_1857299176_n_
re painted the edge of the glass to stop light bleed and i think it looks neater
12080780_10154353900049896_346201465_n_z
12041834_10154353900084896_1821767835_n_
Also started to try and buff some of the scratches out of the front bar. not that it really matters with all the drift stitch going on
12080873_10154353900214896_401183899_n_z
  • Like 2
Spewing about the crash, one of the cleaner 32's in the state, good to see it's being repaired though. Seen it only a few times but always liked it.
Insurance is always a pain in the ass to deal with. Dealt with them before, feel your pain.
drift stitch adds character.
haha yeah the direction this car has headed has changed. before the crash my next plan was full respray... now the plan is skids
thank mate does mean a lot to know i was doing something right :P
ah well trying to be optimistic with the outcome
No worries mate.
Thats all you can do really, i didnt get the choice, just got given peanuts seeings as the car was never found unfortunately.
Looking to see how you end up, secretly hoping you keep it streeted.
Sad not seeing many 32's on the road hahaha.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
