Just as a follow up on the Starlet before we return to our usual programming. Dyno check over. Runs rich but is safe.
Makes 105.2kw/176.8Nm 141hp/130ft.lb on 11psi with the Stock ECU
1 minute ago, GTSBoy said:
Oof. You're not wrong about "rich". I'm surprised not to have seen black smoke on the dyno. Less than 10 is fat enough, let alone diving below 8 at the top end!
First run had some woofs of black smoke then went away for this one I filmed. General driving i tend to see 10.2-11.5 on my gauge.
Still gets 8L/100km.
I should leave it alone and just drive it around but now i am considering a the 2 options of either FCD + RRFPR and see if a little more boost and some fiddling gets the AFRs more reasonable. Or option 2 looking out for a cheap Link ECU to wire in as standalone...
Put a link in.
I'd make the argument that "Just a daily" is what needs the real engine management and real tune for it's driving around casual needs.
You can cut corners when you DGAF for dailying or road use on a car.
yeah i think i accept that something to address the AFRs are on the list for sure.
Interesting how much different(richer) the dyno wideband (exhaust tip) reads than my one reads (pre cat).
I just went through this on the dyno.  - Only to realise most people consider the one in the sniffer on the dyno to run artificially/fake leaner by about half a point.
We trusted the dyno readout. Dang.
Most tuners tend to prefer the one closer to the header location, but also most dyno's will trust their own gear (obviously) and that gear usually involves a sniffer at the end of the exhaust as this is used on every vehicle.
And if it reads 'incorrectly' it reads falsely lean which is safer than too lean.
Supposedly because being (further) inside the pipe means it won't be affected as much by outside air.
Mine is mounted roughly middle of the car, just after where my exhaust merges. No science there - Just where it fit and I wanted it after the merge of a V8. Most widebands request it be 1M from the exhaust port or thereabouts as a minimum.
got bamboozled by the edited post haha
"I just went through this, on the dyno only to realise most people consider the one in the exhaust pipe to be the more accurate one. My car is now tuned 0.3 rich. :p"
9 minutes ago, Kinkstaah said:
I just went through this, on the dyno only to realise most people consider the one in the sniffer on the dyno reads artificially leaner.
My wideband which is post turbo, pre-cat reads leaner. Than the dyno one in tail pipe which is backwards to above. I guess its possible the dyno one or my one is out of calibration. Though mine is pretty new still...
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
