Hey guys,
I've entered for the Sunday now as well and looking forward to getting back out at PI and competing in the championship this year.
For those who don't know me yet I've got a VX SS Commodore with an N/A LS1 putting out around 310rwkw and I ran a 1:54.9 last time at PI. :)
  • Like 1
Haven't entered yet but I will at some point.
Anyone else going for the first time?
At the briefing they usually ask if there are any first timers. Just let them know and they'll either do a parade lap at low speed or get an experienced driver to passenger with you on the first session.
Yep PIARC days they group you on times and shuffle groups during the day on times
Didn't think they did at the last one, might depend on how many entries and the time spread?
They might factor in the car class for groupings along with specified time. Both are on the My Car page on www.meecamsau.com. Most people would be E-H?
Motorsport Information
Group 5 Sprint Class
STANDARD CAR CLASS
Class A - Up to 1600 cc
Class B - 1601 to 2000 cc
Class C - 2001 to 3000 cc
Class D - over 3000 cc
MODIFIED CAR CLASS
Class E - Up to 1600 cc
Class F - 1601 to 2000 cc
Class G - 2001 to 3000 cc
Class H - over 3000 cc
RACING CAR CLASS/SPECIALS
Class I - Closed Racing Cars up to 2500cc
Class J - Closed Racing Cars 2501cc over
Class K - Open Racing Cars. All Capacities
actually most of entrants would be in A-D
E-H are those with engine swaps, stripped down with aero work...think richo's skyline.
http://www.piarc.com.au/files/Feb%202015%20Sprint%20Regs.pdf
Classes A, B, C & D are for road-registered cars using generally road-going equipment only. All cars using racing
tyres, or slicks, will be classified as specials, as will be excessively modified road cars. The organisers reserve the
right to re-classify cars, following vehicle scrutiny. For full details of modifications allowed in each class see Group 5
Speed Event regulations. The organisers reserve the right to amalgamate classes if in their opinion entries are
insufficient to warrant a separate class.
I'm in Class H with my car when I compete at PIARC events...
Anyone that is entered and/or spectating - Please post up to confirm you are coming.
Also if you are doing a single day OR the two days (there is Prac on Sat some are attending).
I need to know for catering purposes for lunch of Steaks/Skewers and the like over the two days.
Thanks in advance!
Thanks in advance!
In for proteins
Just racing on Sunday
Thanks in advance!
Robyn and I will be there on Sunday for sure, steak will be needed :P
STANDARD CAR CLASS
MODIFIED CAR CLASS
I just put down Modern 2WD for the meeca site lol.
f**ked if I know TBH... I just put down the laptimes section though, I think that would hold far more relevance.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
