Hi all
This should be really be in "do you know what grinds my gears"
Every time I go to the auto shop all I see is that every brand claims to be the best, and that really really I mean really gets up my skin..... To the point I wanted to buy the oil and start doing testing... myself at own cost but that’s expensive
1. test I will one day do is a heat test... take 0.25ltr of oil put on lab stove at 300c see how long it take to turn into sludge
test are very expensive so that’s why oil company do them but no one shows their Competitors
showing a test thats said our oil gives you 20hp extra then competitor 1 competitor 2 or 3
to me comp1 could be home brand olive oil and comp2 coles brand motor oil
you get me anyway I gotta cool down just writing this made me have 180 over 120 blood pressure
Enjoy the link. taken me a long time to find, some oils are outdated but it’s the best i got
if you have any independent tests that you got your sticky hands on please share :D
http://www.animegame.com/cars/Oil%20Tests.pdf
Running Royal Purple at the moment, glad to see its good wear properties!
Not surprised by Motul's low wear rating. I have used it in several of my bikes in the past (Motul 5100 and 7100) and it has consistently made them run worse (more cam noise and vibration) than using other brands such as Amsoil and Siloklene.
Edited by colourclassic
yeah... that whole test was rubbish and was debunked shortly after. the magazine even issued an apology
"The information we've learned since then suggests the test we performed may be irrelevant. Some sources have advised us that the test we used would have been better served testing some of our favourite greases rather than the engine oils we commonly use on our street cars. Sure, we did the test with the best intentions, with a level playing field for each oil and no preconceptions as to who would perform better than another, but when, and if, we mess up, we like to think that we're man enough to set the record straight."
  • Like 1
"The information we've learned since then suggests the test we performed may be irrelevant "
But don't believe in every thing you read as they probably had to write that because the big oil boys got upset!!!!! and threatened with legal action against the tester.!!! :rolleyes: Wouldn't you do the same if someone tested your product and found out its shit and realized that you spend all the money on advertising and sponsors and not in research. :huh:
To me this test is viable because it's a wear test which is important aspect of oil testing.
Yes it's not the only test out there are many more test which is listed below but they are expensive and some oil will excel in test others not, I consider that more independent test will show the truth about oils this is 1 out of 13 so I rather lean against this test results then going blind into a shop and picking the one that spent millions on advertising saying they are with technical partnership with Ferrari yes it is in partnership with Ferrari but hay they not going to give you their special additives for you to use because then renault f1 will start using the latest formula.
There is still :
sludge test
Molecular structure
bonding test
Spectrographic test
PQ-ferrous debris quantification
oxidisation test
nitration test
particle size analysis content viscosity after exposure
fuel dilution
soot content
wear debris contamination
SO MY POINT IS DON'T BE EASILY FOOLED.
do research on everything
I hope this opened some people eyes.
As it did for me I stopped using one product and changed to other one
And yes I did notice that my tappet went quieter in my diesel with new brand.
Meh I wouldn't buy a SN rated oil, thats about when they dropped the Zinc content significantly so as the to extend the life of catalytic converters.
True true but you would be surprised with the various types of zinc remember research is the key don't be spoon fed !! With bullshit :D
Zinc Dialkyldithiophosphates two types ZDDP different to ZDTP is a phosphonate instead of a phosphate and is similar to the above ZDDP
But in higher stressed areas the new ZDTP is better off
But this going into advance chemistry. Never mind
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
