If you don't mind high mount for the EFRs then just buy their twin kit :thumbsup:
Me, I'd prefer the stock manifolds and to have the turbs in the factory location :)
Can even use your factory style front pipes with the EFR kit. The full race dumps bolt upto it.
But looks like a disaster under the bonnet
Hi guys, so picked up the HPI dump pipes today. Spoke to the seller and he said the dump pipes should connect to my existing nismo weldina dual 2.5 inch exhaust as the flanges are the same size. I thought the HPI dumps are 3 inch and won't work with my existing exhaust. To cut the story short, I won't have the budget to get the new dual 3 inch exhaust until later this year, my questions is will the dump fit onto the nismo exhaust and is it worth doing it now or wait for the new exhaust and install it all together?
Personally I don't find the standard system that hard to work on, there are a number of people here who have seen me get the turbos off in 2 hours
:O
If your stock dump pipes fit then something tells me that the hpi ones will aswell
I think he means there is going to be a lip going from the 3 inch internal diameter dumps to the 2.5 inch front pipes.
Just do it all at once. Bugger doing stuff multiple times.
can i pay you 2 hours labor next time i need mine swapped?
lol, well it still a bargain even if its a half job??
id then have the option to purchase the re install or
i could now afford to tow it and finish it off myself having saved a fortune and not slicing the f@#k out of my baseball mit hands that fit nowhere.
so for the record im still keen
yep sure thing! one question tho, how do you intend to get it out of my driveway with making a mess? Cause I won't be shy to charge cleaning fees
Ready yourself.
The PMs are coming
:D
  • 3 weeks later...
Hi guys, quick update. Took the pods off and changed back to airbox and took it for a few runs (taking piggaz's advice). Couldn't really tell if there are any improvements with lag, feels about the same. It's alot quieter though so I'll leave them on for a bit and see. What I did notice is that after the first run I left the car idling for a few mins, then going for another run it felt slight loss in power. It seems that the R34 Gtr power is affected by under bonnet temperature. So perhaps the airbox is better when in stop/start traffic.
Will report back with next mods hopefully in a few weeks, just saving up a bit.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
