Leave the poor guy alone. I would also be very edgy after everything he has gone through with this car.
True. Sorry mate.
Sometimes a bit of friendly banter gets taken the wrong way if your not in the right frame of mind.
But the main thing is that Pete beat the Tiida .... That's the main thing even at 10000 rpm. Would have sounded awesome.
  • Like 1
Bit angry today Pete
No mate, its all good fun :)
I have never said I was any type of gun driver, I just like cars :wub: had a 911 and a TT300zx I used to push a bit, but I was a kid, 50 year old.
Everyone has their preferences , mine is a car that dives like a street car, one that has a bit of grunt from down low.
Do not need 3000 idle Ben, is that how you blokes do it. Me at 2500rpm and want to get it going in any gear drop down 1 gear and away you go, LOL
But serious it is great on the twisty stuff, so much fun. Not sure you could do the same on tight one lane roads with a T88 or something else that gives you 700 or 800 peaky HP, but I can only guess as I do not drive fast GTRs , just my heap :)
My car is the best fun you can have sitting down, well , a lap dance maybe ?
True. Sorry mate.
Keep the banter coming mate, that is what makes the Forum fun, farken love it :banana:
Have you got your car back yet Pete?
Not yet James, had an email this morning saying it looks like the leak has been fix but they will do some more tests over the next couple of days to be sure .
Not sure if they will be doing a new Dyno graph , soon see I guess ?
Things are looking up :)
  • Like 1
At 70, I hope to be a much much more bitter and twisted old man than you. Pretty sure I am now at half of 70.
Oh don't worry mate , I was very bitter and twisted at 70 but now I am 73 I have matured , guess it comes with age , LOL
Just thinking to myself.... I feel more anxiety over and your car in than my own. Ha ha. Ha. Might have to drive up from Melbourne so you can take me for a spin when you get it back.
HAHA, that's why I have chilled, I left the anX to you. I lie , I had / have enough anxiety for the both of us. It's been a long 9 months :)
And it's not over :/
Edited by Nismo 3.2ish
They are probably just putting the head back on now pete, takes more than a few days to strip a motor again, lol... :ph34r: apprentice stuffed up again..
Thanks Mark, now my head is exploding thinking about anther 5 months getting the motor re built :bomb_ie:
No problems, I will be picking it up VERY soon and looking forward to a little spirited driving to see how it is running :)
Got a date for pickup? Good RB30 blocks are getting harder to find.
They are going to do a few more tests and I should know by Friday :)
Just hope I got one of the good ones, they did all sorts of tests on my RB30 block, like below
ENGINE MACHINE WORK INCLUDING HOT TANK BLOCK, ACID
WASH , BORE AND HONE , BALANCE ENGINE COMPONENTS.
DECK BLOCK, MACHINE BLOCK FOR O/S HEAD STUDS,
MACHINE WORK FOR AWD ADAPTOR AND ENGINE BRACE KIT.
MACHINE SUMP RAIL TO TRUE UP ENGINE BLOCK.,RELIEVE ENGINE BLOCK FOR 3.2LTR STROKER ENGINE.
1.000 SONIC TEST AND XRAY ENGINE BLOCK TO TEST FOR SUITABLITY
Sounds like they did their best
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
