But I like the feel of it holding the road and wondering when it will let go, thats enough excitement for me, to each his own.
Just a few hours to go before I get an idea if it is going any better, fingers X
I'm with you, but with one change.
taking it on the track, so you can find the limit, and drive withing that.
I like to know where my car is going to let go so I don't accidentally push too far and regret it.
Also, good luck today, I really hope it's all sorted.
  • Like 1
I would be nervous picking it up. Hope its a frickn animal been a 3.2L.
Should have given it to RIPS those boys know how to build a RB30+
The latest R32 that runs 9's is a monster.
Edited by Stixbnr32
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
