wasnt sure where to put this, maby in a nsfw section but,
for your consideration.
billet rb block by ProGTR Motorsport PTY LTD
11169875_962483943796981_464655879914942
11012477_952274661484576_377865054135717
10922665_944021835643192_676449190709278
10406986_943454092366633_100333392102171
10469722_943454069033302_475189932234765
1959945_936375533074489_6808262264988537
11046847_936375516407824_600254821425494
"25kg lighter then the Iron blocks and Capable of 2000hp"
also, why not matching billet head.
11182203_962554820456560_292381656032366
11151011_962554840456558_308870309864608
10956343_962556990456343_286534062632724
  • Like 4
https://www.sau.com.au/forums/topic/456172-pro-gtr-rb-billet-block/
its very sexy but whats the point when theres countless VLs with rb30 blocks doing 8s?
Because you get to a point where you split the block in 1/2 horizontally.
Was at Sydney dragway when Maatouks VL did it. Quite a sight.
Is it for everyone, no. But right at the top end of the scale, there must be a need.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
