Wanting opinions on clutches for a R32 GTR
Power output Will be around 350-400wkw.
From what I gather the Nismo super coppermix twin plate is best stock feeling and rated to 700hp or there abouts.
Is this right?
Drags won't be a huge part of driving neither will big launches but will certainly see some of both. Circuit work being main use.
I can see why people ask questions over n over again.
I'm guilty of it too!!!
So don't worry about this mistake.
SAU search is crap (sorry ) I use google.com search then put sau at the end. finds what I want on SAU.
Use Nismo from all I gather from reading online it's dam good.
  • Like 1
Solid center clutches are much more prone to damaging gearboxes. The Nismo has a sprung center, so TCO may be cheaper once you consider the gearbox repair costs...
Are the Jim Berrys solid or sprung center?
have any of you driven with a jim berry? feels like a factory clutch yet handling 3rd gear standstill drop into powerskid. and only $300 to rebuild when the time comes. Customer service, value for money he is unbeatable
yes it feels like factory if by factory you mean feels like it came out of a 12ton truck
Have driven one and was one of the worst clutches for street driving I have ever used. Nismo twin for street driving every time, feels factory and holds over 475wkw in a Gtr
  • Like 1
Just a FYI, there might be an issue with availability with Jim Berry's clutches.
He has moved shop & I understand is now doing less working hours then before. Last I spoke to him a few weeks back he mentioned this.
So I just got the Nismo twin for my car & all is well. Very impressed with it. +1
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
