Don't be too picky on the exact car you want, even though I may sound like a hypocrite as I was exactly like this.
I would take a R33 over R34 any day simply as it's more of a Pure, streamlined car.
The V-Specs or M-Specs might be harder to find, but the smarter choice when buying GTR's is not to go off by impulse, but to go off by what condition the car is.
If you've ever owned one you will know that they can be costly at times to upkeep in the long term, and a car where the owner has not done that or done tacky mods
generally is a rough car where poor paint jobs, bad servicing will show up later.
  • Like 1
Morning all.
Today, I have work at 12, so I plan on ringing KYP just before I leave to find out if Uneeda actually picked up the door, and if they haven't i'll ring them again tomorrow, and if they still haven't, I'll have to drive over there and find out why.
  • Like 1
On 7/16/2016 at 8:51 PM, RB335 said:
Hi Everybody.
Our next event is locked in, a breakfast meet and greet.  More information on the events page and link below :
http://www.sau.com.au/forums/topic/465831-breakfast-meet-23rd-july-saturday/
I should be able to make it, hope it's not raining!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
