Took the car to Forge Performance, Adelaide for a few things. Fixed up a boost leak which was really really annoying. Figured out the manifold studs had snapped.
Also heres what the second Pedders report said needs to be fixed:
  • Rear Sway Bar Links
Heres what Josh Forge showed me needed to be fixed:
  • Tie Rod Ends
  • Castor Rod Bushes
  • Camber Arm Bushes
  • HICAS rear joints
  • Couple of other non-suspension things
The second set of things to fix also match up with the first Pedders report I got a few months ago.
Time to get to work...
  • 4 weeks later...
  • 1 month later...
Replaced power steering hoses with genuine ones today. Return hose, bottom clamp was a bitch to get off. Ended up just destroying it since I was replacing all the hose clamps anyway. Also did a full flush of the fluid, old fluid didn't look too bad though....hopefully no more leaks!
On 6/30/2017 at 1:27 AM, MagicPants said:
Don't sell man! I enjoy this thread and am picking up a silver s2 gtst next week emoji4.png
Also just out of interest, was your engine bay resprayed ? Either I'm blind or there's no blue build plate on the firewall
Awesome, you'll love it.
Engine bay not sure but there is a Silver plate on the driver side of the firewall that is completely faded. You can barely see the text on it, I need to get it sorted out.
Having fun driving the car in the rain, its so fun when the small slides kick in...
be careful man, they slide easy enough in the dry. Would hate to see you end up like my original 33.. =(
I wasn't even being stupid, just a series of unfortunate circumstances.. No one to blame but myself though.
  • 4 weeks later...
Bought myself a daily today...VF SV6 Wagon.
Skyline going to sit for a while and be worked on....a good day but a sad day nonetheless. Skyline is not gone, she's just resting for a while...
Drove the car after 2 weeks today....forgot how much fun it is to drive this thing...anyway it was washed, photographed and put back in the garage.
Debating between keeping it as is or continuing to work on it....
Anyone know of any good devices to put under the tires to stop flat spots forming?
  • 4 weeks later...
Installed a CTEK MX5.0 charger today. The car doesnt get driven much so a car charger is a must as the battery dies pretty fast...its in need of a new battery too me thinks...
  • 4 months later...
On 1/5/2018 at 3:42 PM, Dan93 said:
Keep your tyres properly inflated. How long does it usually sit?
Yeah I keep the tyres inflated. It sits maximum 2 weeks without moving, I try to take it out as much as I can...trying to save some money before I start to do some more work on this
Hey mate
I’ve found that if I’m not driving mine much I’ll start it twice a week just to make sure she turns over.
I’ll try take it out around the block but if time doesn’t permit then I run her for 5-10 mins. I’ve been stuck before wanting to go out and it doesn’t start because of a flat battery haha!
If it’s any longer than 2 weeks I’m not going to be driving it then I disconnect the battery
Good job getting that trickle charger tho....I need to get my hands on one of those
The tyres should be fine if they're just sitting for two weeks man.
You could have something draining the battery more than usual, mine used to sit for 2 weeks and then have a flat battery. I think it could be that :P
Ive had no issues with it sitting once I get it hooked upto the trickly charger. Took it out for a spin yesterday and it started a bit rough (forgot charger since last drive) but drove perfectly.
  • 1 month later...
Took the car out after a week...was amazing to drive it again. Parked it and realized the brake lights are on...not sure how long I had been driving it with the brake lights permanently on, but drove it home and disconnected the switch.
Time to order a new switch!
You sure it's the switch? Mine did the same thing and realised the rubber pad that the switch touches had broken and come out. Now have a bolt in there instead.
Definitely check this. I had the same problem a couple of weeks ago. The giveaway in my case were the fragments of old hardened rubber in the footwell.
I did have a look at this. I also tested it with the brake pedal depressed, and pushed the switch in and out manually, no change. Based on the setup, when the switch is pushed in, the lights should be off but when manually pressing the switch, they never switched off.
Its a cheap part, will try from a local Nissan Dealer otherwise order through Amayama.
  • Like 1
  • 1 month later...
Replaced the brake light switch with a new one and found the rubber grommet completely wrecked. TBH, this is suchh a stupid design.
Anyway, changed it with a bolt and lock nut so shouldn't have this problem again.
Pic: no switch installed...
Edited by shubby0901
Update information
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
