So, Returned to this happening to a parked car...someones backed into it and drove off.
Initial assessment of parts to be replaced:
  • Front Bar
  • Headlight
  • Grill
  • Reo
...yay.....?
Edited by shubby0901
Typos
  • Sad 1
  • 3 months later...
Car is all fixed...well cosmetically. Got the original front lip completely repaired so its in brand new condition! Gotta stay away from the kerbs now.
Headlights are polished but still have marks, one of the lenses is cracked. Have people replaced headlight lenses? Is it easier to replace the full unit?
Also the actual lights arnt working. Hopefully just needs new globes...
  • 2 months later...
Slowly pulling the engine apart to get the fuel rail and injectors out...the car is running very rich so I want to get the injectors cleaned and flow tested...are there any stock bolt on replacements which people use?
This is what the car looks like at the moment...
  • Like 1
  • 1 month later...
Its been too long since I've even looked at my baby...so yesterday I sent 2 full fuel rails with injectorsd for testing and a refurb of the 6 best injectors to make a set of good OEM injectors. They will be good till I get upgraded ones withc a tune...but first, some of the easy but essential things...this is step 1
  • 1 month later...
After a heap of struggle, got the fuel rail and the car back together. Put 150km on it over the next couple of days.
For anyone who has issues with their cars running rich, I would highly recommend this. The smell of fuel (and actual fuel being shot out from the exhaust) has almost disappeared. The car revs much smoother.
A good cheap mod (is it a mod if its OEM part)! Now to think of the next thing.....
Old vs "new" rail...
Its just easier to get the bonnet off completely and work on the car...spacer.png
  • Like 1
On 8/26/2019 at 11:01 PM, Milkmun said:
How much did thay set you back chief?
So $50 for a second hand rail.
$375 for testing of 12 injectors, and refurb of 6 injectors and 1 rail
  • 1 month later...
Pulled her out of the garage last week, gave her a rinse and drove her abour 150km in one day....so much fun to drive.
Issue's do arise though, by the end of the day while driving home the indicators stopped working. Turning the hazards on still turns ythe indicators on, but using the stalk, nothing works....gotta pull it apart now...initial thoughts of comon problems?
  • 1 month later...
  • 1 month later...
Hey All,
I endedup just getting a stalk from a wrecked R33 and fitted it but same thing, no indicators. Next step is to trace the wiring to see where it has failed. Any ideas about other common failures?
  • 1 month later...
A heap of messing around with indicator stalks, fuses and rewiring of plugs, the car is working again.
Now to get back onto the 200,000km service that is requried ASAP....
  • 1 month later...
 Fixed up a couple of little niggly issues and installed a bright LED strip in the boot to replace the standard bulb...makes the car look way nicer and way more..european weirdly.
Currently lookong at headunits for the car. Debating between a Chinese branded Andrpid powered unit or a name brand Android Auto unit....
  • Like 2
  • 3 weeks later...
Working from home means small breaks are for working on the car...started to clean the engine bay, actually very surprised with the results!
This is my process:
Bowdens Orange Agent spray
$1 paint brush to scrub
Wet MicroFiber tower to clean up and let it air dry
Working pretty well. This will keep me busy until the parts I have ordered come in
  • Like 1
Working from home is annoying becauseyoure tempted to work on the cat but cant because you need to actually work...anyway snuck this in today. LED lights in the footwells. I did the same thing before aswell but it never worked properly...cheap LED strips also meant the adhesive died after a small amount of time. This time, decent strips with proper 3M Tape...its looking nice
Bits of the dash are out for a new headunit that is on its way but stuck somewhere due to COVID19....grrrr
13 hours ago, Milkmun said:
Good job man, been wanting to do this as well. What did you cut the power source into?
I ran power from the dome lights, down inside the A-Pillar trim and then did the connections in the kick panel. It splits into 2 from there, one to power the driver side and one for the passenger side.
Working on a bigish project on the car right now...but waiting for some parts which have not arrived due to COVID. Who else is affected by this thing?
In the meantime, I bought some Stainless Bolts to try and see what I like the look of and am thinking of slowly replacing the bolts around the car
Thoughts? I am not sure if I like the socket head.. also needs washers...
  • Like 1
Been following the thread and love the car; have recently (Feb) purchased a 96 S2 in same the same colour. I have got the Type-M rear pods and side skirts, but I really want the front lip like yours, is it part of the front bar or a seperate piece? I see fibreglass ones for sale but I'm going to chase down an OEM plastic one. Car is looming great BTW, I'm doing similar stuff to mine i.e stock, OEM mods/replacements with a few subtle upgrades.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
