Anyone in Sydney that wants to do there’s to save buying the socket to do it, I’m happy to lend you mine if you leave a $50 deposit which will be returned to you when you return the socket
  • Like 1
  • Thanks 1
9 hours ago, r32-25t said:
Keeps the pressure in the pump, easiest way to know if yours is stuffed is while car car is sitting there idling you’ll hear the attessa pump cycle every couple of minutes.
Pretty certain my attessa pump primes every 10 seconds lol
I'm keen to know how did you find the change in ratio's especially for driving on the street in comparison to the 5spd box?
Does it make more sense re ratio's of 6spd v 5spd? and  the 4.11 rear diff.
Doing the same conversion and getting a tad excited, cant wait so trying to glean what you think.
I actually think it’s easier to drive especially taking off, I find 4th at 60km sits just under 3,000rpm which gives it a nice amount of torque when you come to a hill, get to about 70-80 and I put it in 5th and it just cruises along nicely
It’s great with the 4.11s, honestly if you have any reserves about it, don’t worry about them cause you won’t regret it
  • Thanks 1
Thanks - watched it several times listening to the changes. I absolutely love the sound the RB's make under load and the BOV's.
I'm really chuffed to hear you say it's easier/nicer. I cant wait.
Edited by Sinista32
In that race I was against an r32 Gtr with a big single and more power then me and he finished with his front bar lined up with my rear cause mine gets out of the hole so much better
  • Like 1
  • Haha 1
  • 4 months later...
Nothing “broke” but the ats twin plate while being a fantastic clutch was not strong enough for the mighty twins and slips when I run anything above my lowest boost setting
The clutch to replace it will be an os r3c that I picked up a couple of months ago from a member on here with very little use on it
after ripping the box out I sat the 2 clutches side by side and I realized this wasn’t going to work without some parts sourcing
After installing an r3c recently in my Gtr
make sure u use the correct length bearing carrier as the clutch is “thinner” and needs a long bearing carrier
mine was around 27mm long if I recall where as most other clutches require a 14ish mm carrier
  • Like 1
I did a heap of measuring and had worked out that was what was required and late today I picked this puppy up and it will fix my issue
I will be able to fit it all when I get a free second and take it for a drive again
Honestly I have no idea, Kyle from hi octane had it sitting around because their supplier had sent them the wrong part for another customer and he sold it to me.
i will check it for a part number tomorrow
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
