On 8/12/21 at 11:05 AM, Dose Pipe Sutututu said:
That's pretty decent in terms of pricing, tempting LOL..
For the money you’d be crazy not to, putting old manky looking bolts in a fresh bay makes it look shit
  • Like 1
  • 3 weeks later...
seeing as I can’t do a great deal with the front at the moment I decided to do some work at the back of the car
in go some rear camber arms to stand the wheels up a lot more
once installed I dialed the camber down to half a degree, the toe is still all over the shop because I didn’t have the string lines to be able to measure it
  • Like 1
On 6/1/22 at 5:31 PM, r32-25t said:
I got told yesterday the pistons have arrived and will hopefully see some progress with the engine soon
2000hp on the way 👍🏼
  • Haha 1
On 07/01/2022 at 8:18 AM, r32-25t said:
Lol there no way I’d put up with the lag a turbo big enough to flow that would have
Never say never. You said that about never putting a single turbo on your car too.
Quoted for future reference. 🤪
Lol and that improved response not killed it
Well seeing as I couldn’t go to work because of getting beer flu I decided to work on the gtr once I had enough energy.
Pulled the rest of the interior out and removed the battery wiring, the battery tray ready to re wire the entire boot. Then I fitted the surge tank in the corner of the boot
then started plumbing the tank into the fuel lines I already had
I had to wait for 60° fitting to do the last line as it wouldn’t run where I wanted it to without it
I’ll be wiring in some solid state relays and etc, just need the engine to turn up and the new wiring harness before I wire it all up
  • Like 1
Fitted all the brake lines back into the bay with all new clips to hold them onto the firewall
also fitted some nismo braided brake lines as they follow the factory routing and make a lot less nervous that they may end up touching and rubbing through
also some new break clips as it seem the old line stretched the original ones
  • Like 1
Then I bled all the brakes using good quality brake fluid, put all the wheels back on and now I pretty much can’t do anything until the engine and wiring harness arrive
Looking nice!  Hard to beat a nice clean engine bay!  I see you’ve given the ABS module a tidy up?  They’re a tricky shape and setup to be able to do much with. So tempted to delete or relocate mine.  Even just route the pipes somewhere else. Lower on the firewall maybe?   Or just stop being a wanker and finish the car! 😂
  • Like 1
I had it vapor blasted then put it back, I wanted new lines but a few a discontinued
On 29/1/2022 at 5:32 PM, Old man 32 GTR said:
Wiper motor looks nice as well, how did you clean it? Or did you buy new?
i also had it vapor blasted and then painted the black bit to make it look as new as possible.
On 1/21/2022 at 7:43 PM, r32-25t said:
How have you found the steering feel with the pump in the boot?
On 1/29/2022 at 3:02 PM, r32-25t said:
Engine bay is looking great.
  • Like 1
It’s good, if it wasn’t for the fact you can hear it wind up before you start the car you’d never know
thanks mate
Something little but has been a pain in the ass for ages
the spring for the fuel flap went missing when I gave it to someone for paint matching years ago and I was able to buy one new
quickly clipped it onto the flap and now when I open the door it pops open again. As I said it’s a really small thing but sometimes they make big differences
  • Like 2
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
