Turned the engine over, to have a bit of a look
A40EA978-9099-460D-BE12-B421353111DC.thumb.jpeg.00322e782929a03c3e265ef15517eb51.jpeg7FCD03D3-EE47-4006-9DF7-239789536177.thumb.jpeg.efecb88bd94c20a0eeb3f7b5a2243cb8.jpeg
as You can see the oil squirters go back in with the billet block
then I threw the sump on with a brand new set of bolts,
something I have noticed is if you use a billet block, you need to invest in some bottoming taps as the blind threads have not been cut deep enough
  • Like 4
D2571ECD-1918-4799-B1F8-B72FD852167B.thumb.jpeg.142b765000b96b5f3fa39abe59c36398.jpeg443CCD13-B6ED-4345-BB78-B85572724FD6.thumb.jpeg.3501127b0814f6ecfeeb2baa6f8c276c.jpeg
fitted the ac compressor and shifted it forward onto where the power steering belt used to run
F04CAF6A-B6A0-4CED-B518-E26C59C01157.thumb.jpeg.7aaba98ff0f9c5e82370eebef955d08f.jpegABEC5829-CE26-4142-AB5D-B1870416AA07.thumb.jpeg.ea0fa502f41c8914907f24366d97c5b5.jpeg
fitted the new passenger side mount, hopefully I won’t be breaking this one in a hurry
fitted a nismo mount on the drivers side, I know they’re probably just stock ones but I had it so I fitted it
  • Like 1
From my personal experience, the Nismo engine and box mounts are definitely stiffer, not ridiculous but noticeable none the less.
The box mount improved shifter feel in the 34 to me, I guess by taking some vibrations out.
Nice mate, she's looking good!!!!
I just bought one of the PRP a/c compressor relocation kits too.  Sorry I should read back and/or remember but are running electric p/s now?
Yes, I fitted an astra power steering pump in the boot when I put the single turbo on, I looked at a few options of using the original but wasn’t happy with any of it and just chose to get rid of it
  • Like 1
I guess the verdict is still out, it could have just felt stiffer because they were new but then again they could actually be different
Spose it’s a bit like changing 25 year old suspension bushes that are cracked and flogged.l with factory ones. All of a sudden it feels like a new car.
  • Like 1
100%
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
