4 hours ago, Shoota_77 said:
@r32-25t where did you get your coolant swirl pot from?  It's a very nice bit of kit.
Be prepared to wait for months and be ghosted by the manufacturer
  • Like 1
It’s the hypertune one, they give you the option of being in front of or behind the strut tower.
  • Like 1
 the radiator didn’t take to long and arrived pretty close to the estimated time that they gave me
They've got about 5 years to make it which is approximately when my car will see the road again....
  • Haha 3
I hope by the time you car is running, I will no longer own my Nissan shit box.
We all can hope and dream, it keeps us feeling alive :D
  • Haha 4
I hope to trade my shit box in for a new lotus Emira, be nice to have a car I can actually drive and enjoy
  • Like 2
And do wild lap times, and then head home with the same tank of fuel and not get carjacked or cops fisting you or neighbours sending your car details to the EPA.
In 10 years time, own anything that runs on petrol and you'll be fisted by the EPA, PETA, and the Greens :P
  • Haha 1
Also, still waiting on diagnosis as to what let the coolant out...
I'm presuming you only filled, and werent pressure testing, so worst case is something like Welch plug not in correctly or missing... However, I suspect something more normal, like, someone forgot to connect a heater hose to the heater box properly, or missed one of the many random lines under the plenum. And that's making Brett consider just selling the whole thing rather than trying to get back under the plenum in a GTR to fix a fiddly hose :P
40 minutes ago, MBS206 said:
It will when they line up preparing to ban petrol vehicles outright...
Then hopefully they word the rules in a way, they mention petroleum, fossil fuels, etc.
That would mean 100% ethanol is fine!
Back to Brett's leak, I reckon send its mum to the moon with RTV. Just don't do what Subaru did and leave bits of RTV everywhere lol.
I wish it it was that easy, being a billet block there’s no Welch plugs in it and pretty much every line under there is gone now and the remaining water hoses are bmrs because of converting it to dbw
6 hours ago, r32-25t said:
And no I didn’t pressure test it, at least it didn’t come back out as fast as I put it in but still didn’t require any pressure
So where is it coming from?
I hadn’t got much of a chance to look at it properly as it was dark when I filled the water. When I finally did it appears to be coming from behind the housing that the water pump and thermostat attach to.
  • Like 1
The engine is stripped down and the housing removed
this oring is the the culprit (so I thought) and I smeared it with rtv and fit it back on. A few days later I fitted the parts that allowed me to fill the water and out comes the water again 😡turns out by doing what I did I just moved the leak further up the block
  • Like 2
Bummer...
Is that a groove in the o-ring?  Is there a lip or a gasket protruding that is cutting into the o-ring?
Also, good to see you're wearing Chinese safety boots.  Too cold down here in Victoria for those at the moment! 🤣
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
