25 minutes ago, MBS206 said:
Evidence girls always fall for shiney things :P
Brett, I do NOT envy you when you're going to have to try and keep that shiney!
Just lick it clean.
What it’s supposed to do is go like polished copper colour once it gets some heat through it
  • Like 1
Hey Brett,
Before you even get this running, I've found you an upgrade I think you need to order...
https://www.facebook.com/100064809843530/posts/846738300829824/?mibextid=rS40aB7S9Ucbxw6v
And it's made locally to you too!
Go on, you know you want one to match the billet block...
  • Haha 1
5 hours ago, MBS206 said:
Hey Brett,
Someone already beat them to it and made a billet rb26 head and had it on display at gtr fest
Took a little trip
went to nismo hoping the get my fuel tank hoses and unfortunately they told me they didn’t have stock
luckily I was able to go to a Nissan parts store and they were able to order them in for me
IMG_1116.thumb.jpeg.fd07de853decd1fe058d3aa19bd42f5f.jpegIMG_1117.thumb.jpeg.40f4d1a52e2d0e78391e092c77d51ac1.jpeg
then can home and cleaned the tank with some degreaser and fitted the new hoses before putting it back in the car
  • Like 4
4 minutes ago, r32-25t said:
put the front bar back on so I can measure the new spot for the oil cooler
sitting in its new spot waiting for the hoses to come back from being crimped
I like your garage!
  • Like 1
Front bar is attached for the good now IMG_1151.thumb.jpeg.89d86ae99a460d79d1b71e9b4bb00d39.jpeg
put the head lights back in
decided a new set of blinkers would make it look fresh
fitted them along with a new set of clips for the front grill and now it looks like a car again
even fitted the volks back on
  • Like 1
IMG_1164.thumb.jpeg.19c5fbda441dab32111192ba1e696046.jpegIMG_1192.thumb.jpeg.0a429203d9476510821701674e518c45.jpeg
more new rubbers and to add to the mix
also new bolts for the center garnish
and pretty much all done, the alarm is being replaced and I’ll deal with that ugliness when that happens
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
