Your plugs will more than likely to be covered in junk by now.... this will cause the increase severity of the misfire problem.
You can learn a lot from pulling the plugs and 'reading' them (although it may be to late now). I'd suggest you pull them asap and post up photo's (keep them in order).
Replace the plugs and at least you will be able to drive it again for a few km's.
Honestly I can't see your O2 sensor being the problem (just unplug it if you aren't sure), fuel filter is a good service item, but unlikely to stop you from miss firing. A wide band is only going to help if the mixtures are actually getting burnt.... as soon as it misses, you will just get rich afr's off the scale-
I'd be buying/borrowing a new coil pack loom and a known good ignition module before buying another set of coil packs.
If you still have issues, pull the injectors and get them cleaned/flow tested.
after that... take it to a mechanic.
I had similar issues with my R33 s2.
I had checked and resoldered the pins in the afm for the plug, made no difference, but it was actually dry joints on the afm board itself. Fixed those up and she's been apples.
Also, is the z32 afm genuine? There are copies floating around
Xrated, it's a s2 motor so the ignitor is built into the coil pack. Unplugging the o2 sensor doesn't make any difference atm so I'm replacing it anyway.
Cef33y, I'll see if anyone in town has a z32 afm I can borrow. I double checked and mine is genuine.
I had the same thing happen to my Stag. I was sitting at the lights one day and it started running real rough. By the time I got home the car was real rough. I turned it off and it wouldn't start again. Checked this, that and the other, no good. Pulled the plugs and they looked OK, although a touch dirty. Changed them and bammo, car fine again.
Jam a multimeter in your car and see if your voltage drops as there's load on your motor or if you can just log it from your ecu.
I had a shit house misfire problem too, turns out was my stock alternator playing up. On idle, it would show up 13.8V but as soon as you increase the RPM it would drop to around 12.2V. Replaced it with a brand new Circuit Sports one and misfire gone!
New coil packs, new 02 sensor, new tps, new plugs. Starts, Idles and drives fine and smooth. As soon as you try and boost it, feels doughy as and misses and doesn't make any power. Still yet to fit a new fuel filter.
Still have to find another afm to try yet
Any workshops in Alice Springs NT you could recommend?
Its something that isn't affecting just 1 cylinder as the last lot of plugs were all sooted up. I just feel like I've gone over everything twice without any luck.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
