Hey guys, so apparently I need a metal intake pipe as the stock plastic one is too small and can collapse under pressure with the new, larger turbo (ATR43SS). Wondering if anyone's done a DIY using silicon joiners and steel piping and would like to part any feedback. Also wondering if the return BOV and breather line are essentials ? Or can I simply make the intake, block the BOV and get a catch can to bypass the issues ? Thanks for any information.
It's on a rb25det pod filter setup
https://www.sau.com.au/forums/topic/458052-metal-intake-pipe/
Search for 'Scotty's metal intake' on these forums or PM scotty nm35. He's made hundreds, they're cheap, have all the breather and pod adapters and are great quality. I run mine on a very similar set up to yours by the sounds of things. I have pics if you find my build thread
I've spoken to Scotty, but considering he's in Melbourne and im in sydney it would be a little hard to ensure right specifications and stuff. What do you guys think of blocking the BOV and getting a catch can to get rid of the lines into the intake ?
I'm in Sydney. Seriously just get him to make it and be done with it, he's made hundreds for people on the forums, if he couldn't ensure 'the specifications and stuff' don't you think someone would have mentioned it?
His specs are spot on, all my breather lines and BOV return fit perfectly with no mods and it works perfectly. Don't make this any harder than it needs to be
Truthfully, get Scott to make one, and then alter your setup to make it fit right IFFFFFFFFFFFFFFFF it doesn't.
It will be far easier and a better solution to do it that way, and re-adjust your setup to fit the scotty pipe if there's some part that is out by 2mm here or there.
Hrm breather line and bov return needs to be cut, there's no way around it unless you use a soft intake pipe
Correct, otherwise the BOV/Breather hardpipes would somehow be inside the intake and facing the wrong angle causing AFM reversion.
I tried to make an 80mm intake that would look as stock as possible using all the stock parts. Seems to flow well too, ^^ Gregs made very good power yesterday, using the stock airbox. :)
Got your graph up yet mate? I think you made more power though one of my rb25 80mm intakes intakes than anyone before. Usually I would be suggesting a 4 inch with pod by now, but it wouldn't look stock at all. Your car is about a stealth as 400+kw gets, and it's auto... Blows my mind what Ethanol can do. :P
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
