Luck and the name
So much luck in that game
Because of the name I had random people throwing me food which got me reasonably sized, then I ran into some huge guy who was split up and I took over his split cells one at a time as he was cornered. Then people kept feeding the cause lol some people just sacrificially dived into the cell.
i feel bad for the dude, i do... but how do you not do any research into a) the seller b) the actual value of the car and d) get it checked prior to purchase and/or listen to what they f**king told you
http://www.dailytelegraph.com.au/news/opinion/was-this-car-purchase-a-rip-off-or-a-wind-up/story-fnlrw4is-1227462226858
Told ya D1Rs were awesome
Don't think I would've posted that particular video as an endorsement of D1R's..
Hamish has curiously bucked the Lefty trend on the Adam Goodes issue
There's a little bit of good in everyone
What's my stance supposed to be on this issue? Whatever it is, f**k Adam Goodes
It's a non stop f**king cringe
He's in the shit now over a Stagea someone's taken him to court over
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
