Workplace gossip (among a very small subset), and now confirmed in an email to them, is saying that I've been to a meeting with a company I know a few employees within. Not that I'm actively seeking work at other companies, but I'm seeing what options are available to me if I was to move on. I have expressed a desire to stay, but also stressed that I need to do what is right for me and that financial incentives are important to me at this point in my life...
If they want to fk around, then I'm happy to begin actively seeking work elsewhere... I'll wait and see how they read into my email over the weekend.
In the meantime, I'm waking up at 5:15am tomorrow to go to Winton... then coming home and getting slaughtered on cheap jack and coke at my fav "this is where I go to get drunk" restaurant.
  • Like 1
Next time on 'Days Of Simons Life' will he get said pay rise? how will Kate handle the change.. will moving to New York put stress on their relationship.. tune in at 5
maybe that could be the trigger for Kate to move out of the friend zone......or keep in there 20000 km away..
Sorry Simon but I'm gonna have to call your girlfriend up on that (not literally call, I won't be cutting your lunch, no fear)...
Guys are being honest about their intentions by cutting straight to the point - would she rather these guys play her by pretending to be interested in dating and cups of coffee when all they want is TnA?
This is a picture of a train driver in Singapore....
I'd probably thing REEEEEAL hard about demanding an 18% pay increase if I was representing train drivers lol
I wouldn't expect to see any of those here any time soon
Self driving trains? Good luck with that.
Hell it cost us 3/4 of the cost of an exploration trip to Mars, just to get a make our own 'smart' ticketing system... Instead of buying a known working system from Japan/Singapore/etc for 1/4 of that price.
  • Like 1
Really need to organise a marketers union and get in on this undeserved way above inflation payrise age of entitlement stuff - missin out hardcore on some undeserved benefits
  • Like 1
There is a driverless car being tested in Radelaide as we speak
Radelaide is 4 blocks of churches and a bunch of slackjaws on pingers.
Nothing about Adelaide is relative to our interests.
That was pretty much my point
Except for the fact that we are rolling out the largest autonomous rail from mine to port.
  • Like 2
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
