Men?
I can't stand auto, so boring. Granted I've never driven a decent one
Man if ya drive a lot manuals a drainer & not very luxury.. Mates got e92 m3 manual which is awesome but he doesn't drive far at all..
The new autos are amazing too
Do you also find that your high heels get in the way when you have 3 pedals?
  • Like 1
I see julia gillard hasn't had an impact on you casual misogynists!
Manual is ghey. Unless your driving a skyline or similar old jap car that makes it worth while who could be bothered
Did lol
The ONLY benefit of auto is you can use your spare hand to warm your mrs up on the drive home
  • Like 1
Yeah you wouldn't want any form of gender bias on JG's watch...
Incidentally...
HOUSE FOR SALE FORMERLY OWNNED BY A WOMAN WHO WAS AUSTRALIA'S FIRST FEMALE WOMAN PRIME MINISTER WOMAN WOMAN
Incidentally...
Who gave the listing to a woman be coz woman, did j mention woman who sold it to a woman
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
