Barry believes it, with E85. RB26s with 98 make about 340-350 with GT-SS.
Im not sure of the state of the car itself, but fair level of supporting mods to get it up to 400 i thought. Solid fuel pump setup, big exhaust (and all the GTR conspiracies that come with twins), clutch... Im sure there is other stuff i havent thought of.
i'm just going to throw it out there... but has anyone considered that the RP dyno might just read lower than others?
(not that it matters in any case)
It's all marketing...
- make the dyno read low where people have money to spend for more upgrades
- make the dyno read high where people are a one-time show so they can advertise & bring in more business
illuminati
Yes but not nearly as fun as paying out hub dyno people for thinking they have more power than they do
  • Like 1
I can't see there being an issue with it hitting 400 on e85... it would be absolute max but should be possible
Yeah either way I don't really care about the top end power figure; never have. Within reason (obviously I'll be shitty if it finishes up at 250), but it's the midrange and linear torque I want here. I judge this by acceleration and seat of the pants alone.
Will never forget the '450rwkw supra' on e85 at the chasers dyno day rocking up with skinny 17s on the back did a bout 10 runs to try and beat the 2 falcons :P
Yeah the falcon 4l turbos are quicker than the 5l v8s (at same or similar power) because of the power curve pretty much constantly on their max power output whereas the v8s wind up. My power on a 6 pretty much runs 10s
Can't beat dat dere instant torque and response on the 8 doe
Whats eta on your gtr?
Edited by UNR33L
As soon as Barry gives me an ETA I'll multiply it by 2-3 and let you know
Waiting for some parts at the moment apparently
Doing some oil supply bulletproofing
Only has to be 50% of value for write off I thought? 2k excess sucks but that's nothing compared to what i'd get paid out if needed
Daily driver but I think on policy is only 10,000km a year
Edited by UNR33L
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
