Don't know what's a greater achievement, doing a track day or having the car actually survive it, bar the a1rms destroying my rotors lol
I hope you wont be daily'ing on A1RM's...
I chewed through a brand new set of rotors using A1RM's through daily driving.
Had a chat with the marketing rep - advised me that when pads are cold - they chew through rotors.
He advised me to switch to HPX & I haven't had any issues since then.
Probably unrelated though; however did you fit new pads without machining rotors?
Didn't need it, shoulda done it, but I was cutting it close with time lol, had a monster oil leak to fix as well
Maybe they are going for the "buy this car and you can look like me" angle?
Fastest Copen in Australia? Love how he says he can claim that, then proceeds with no subsequent evidence. Cause of an exhaust and GT wing?
Also annoys me when I see people with a 2 million dollar car who can't string together a sentence; "It has 610kW engine with 860 BHP"
But you didn't get full $$ value from track day as you were limited by warped rotors????
#mohlogic
Came out of the last turn steering the opposite direction a few times = max value
but i do need dat BBC tho, no homo
yeah have to do more! the crest at the back is a bit scary, followed an 86 in and kinda watched him do it, then decided hes a f**king mad man lmao
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
