Birds, on 14 Oct 2015 - 2:42 PM, said:
Auto / manual
Does not compute, does not compute
Was SST though
Also drove housemates SR20... also does not feel laggy.
Honestly kind of made me think the RB25 is pretty f**king laggy for the capacity, given how good other 2.0's actually seem to be relative to it
Felt a bit like the 2.5 Subaru engines being 2.5 to keep up with Mitsu's 2.0
You have a huge turbo on yours though, don't you?
Can't compare response with nearly twice the power
After driving a slightly Modified 8MR, then getting back in my car, off boost wasn't as annoying for me anymore
Was SST though
once im running boost ill take you for a spin. not sure what you interpret as "lag" but big cams certainly hold things back (until on boost...)
driving car home tomorrow :) been a busy few days on it.
that's cos it got outsourced to the singaporeans, same as citylink.
If there's one thing Singaporeans can do, it's build shit
Using people from the rest of the world
Car related question: do I need gasket sealant to install a catback..? or is it recommended..? or just the gaskets good enough, keeping in mind it's a cheap-ish x-force exhaust..
Edited by UNR33L
net glitched out.
got locked out of our NAB business account.
account is in my name and partners name.
nab acknowledges that i am also on the account, wont give me a new password.
partner is currently OS.
daf**k man.
Couldn't tell you what to do without being at work. End of the day it will all come down to what paperwork you signed when you at the account up initially. If it says both ID's required then you's in for a bad time
Not really that huge given the difference in displacement, but I guess its gonna be noticeable at under 100kmhs in any case.​
260RWKW in a SR20 did NOT feel laggy. It was enough to kick the back out at 30kmh in 3rd at part throttle, boost is pretty much on any time you hit the throttle.
I guess it depends on how much powarz you are making on your SR20, the example I was using is a GTX2863R at about 260RWKW, but at the same time feels like its the sweet spot, would lack traction at much more than that, and just get lag for no real benefit.. in that specific setup.
it is entirely possible my car is a complete clusterf**k nugget
At least you're out of the way for Headspec to start on mine now, i.e replace a head gasket so I should be good to go in 2021.
lol. yes it did take a very long time for me to get my car in there, but was kinda my fault it took a good part of a week to get it out the door. thank you for your patience. (but also keep in mind ive been on the imaginary waiting list for many months).
similar power on same-ish turbo. but big cams, FWD and less weight. traction only an issue if driven like a muppet.
dont give up on car just yet, may need an open mind to overcome some gremlins though.
tbh I have ordered the gasket and studs but they haven't arrived yet. Will be keen to see what actually happened, as it was picked by my keen spidey sense of "SOMETHING IS NOT RIGHT" which has been honed by destroying everything over the years.
I may end up going a 1.06 rear "just because" because HS believe that I've lifted the head due to backpressure, even though you'd think a .82 on a GTX35 would be enough to get the air out.
But then again, who knows what'll happen once it comes apart. I will be pretty keen to see what studs were actually in the engine, if they were ARP2000's after all then they were under-torqued on the blueprint.
If its only that, I'll be a happy f**kin camper lol
from what I've heard (and its all second-hand info if you know what I mean), the last motor was bit warped and you're running stock head gasket on a big power/boost 2.8 setup? i know its a metal gasket, but thats a lot of boost. Tony runs factory, but he's got a big-ass turbo with less boost.
there is talk of an underlying issue that hasnt been addressed causing this warping. wont know till its torn apart.
As it should be
And greg pls...no car is kicking out at 30km/h in 3rd gear without a clutch dump on shot tyres in the rain!
There's nothing magical in the Jap 2 litre engines, unless very high comp and E85, that's going to make them more responsive or less laggy than a 2.5 with similar top end power. I'm yet to drive one more responsive than my 2.5 that doesn't die in the ass after the mid range cause of its tiny turbo...happy to be shown otherwise...
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
