From what i've driven, high comp makes the boost instant, full song around 4k till 8-8.5, which is alright with hondie ratios
Car is 1ton like pulsars, 2L plentyful off boost, gets off line really easy, but then we're drifting off to the silvia vs skyline chassis hear
From what I'm seeing in that graph, definitly not peaky, lots of usable power
Referring to the 300kw one above, is similar set up to mates integra.
Im just bored ok
felt like spamming
f*k yas
4000rpm =/= instant
tweeked Std turbo here.. with a BOV that promises 15% better response again...(not the reason i bought it) that's as good as response as your really going to get.
and I can light them up at 30 in 3rd..(on the deca skid pan with a kick and maybe a puddle)
4000rpm =/= instant
Different things
there "turbo lag" where how long it takes for the turbo to spool up as soon as you step on it (say at 5000rpm you should be at full boost, you're cruising at 5000 cause you're deaccel, then you punch the gas, the lag time between none to full boost)
and "turbo lag" where how early in the rev range full boost is experienced
So easy to hit 4000rpm with honda ratios, heck we sit at 3.5k rpm at 100 in 6th with a type r box
If I'm driving hard and want good response:
Step 1 is BEING IN THE RIGHT GEAR!
You don't need power at 2000rpm, you should have already downshifted two gears and getting it into the peak power band of the engine/turbo setup.
So for me, response isn't about RPM, it's how long the turbo it takes to come onto full boost when I stomp the loud pedal and I'm already at 5000rpm.
A decent power curve is nice below there, makes everything nicer on the street. But don't expect to make balls to the wall power AND have all the power down low in a turbo car, or it'll run out up of go after you get above the midrange (which is where you'll be if you want to go fast)
I'm talking about manuals of course, because fk autos
Hehe, i like how we both used 5k rpm :rolleyes:
What car you driving these days Jonoe?
stock dc2r for daily, ek going under some works but will take a while since most of my money just went into holidays. Graduate end of this year :D
What's a pulley upgrade?
:rolleyes:
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
