at first it hought it was toyota plenum, then found someone in the UK selling them on ebay...
Dude there is thread upon thread upon thread on this in both SAU FIP and Facebook... there has been for yeeeeears
Also as simon said it's a shit idea as it always leans out a cyl
Dem cop troubles doe
As true as this is the reality is I've been defected once in the last 7 years of ownership...not saying it won't happen to me again, but I reckon it's died down heaps since I rarely see imports in my area these days.
I might get looked at closely for tickets etc. but most cops don't give me second looks from their cars.
Agreed, I do think it has died down a bit over the last couple of years.
i'l just post it here and all the dream boats that have my number can update it if they want zerofouronetwo90551five decrypt and you have earnt it fella *inb4 mohsen sends me dick pics*
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
