So work floated a concept past the team.
Work for 4 years at 80% pay & then have the 5th year off.
Interesting concept.
Thoughts?
My maths might be out of whack, but how does this create an advantage other than for people who don't know how to save money? Like can't you do 4 years at 100% and take a year off for the same result?
Let's have a look at the historical mean and standard deviation to see if it is a start to a shift. Could knock up an IMR chart.
Woah let's not get crazy...one tailed or two tailed?
Your maths is out of whack.
Thoughts?
Do you get your annual leave in the 4 years aswell or is this a cunning ruse to get long term staff and rip everyone 4 months leave?
Your 5th year would be at the 80% salary rate along with the previous 4 years.
Would also assume it would be a 20% saving pre-tax so it would equate to a 80% paid salary on the 5th year.
Well you are still working 100% of the time and annual leave is accrued for each hour worked. So I would assume it would still be the normal 4 weeks annual leave.
It will just be paid out at a 80% salary rate.
So aside from the tax benefit is there any other advantage and can we explain this to me?
As far as I can tell, they're docking you 20% of your pay for 4 years and then giving it all back to you in a 5th year you're not working...unless it puts you in a lower tax bracket it doesn't seem to leave you any better off financially than if you just worked 4 years at 100%. It's like superannuation; sounds like a good idea for FIFOs who can't save money?
Only other advantage I can think of is that, unlike most jobs, you can take a year off / gap year for overseas trip / self actualisation journey and come straight back to it.
Yeah probably the advantage is having a workplace willing to let you go for 1 year leave. The tax bracket benefit would be an added bonus.
80% Salary = less chance for you to save money over 4 years and put into your mortgage or investments.
Then you're without work for a full year, and in my experience you have higher outgoings when you're not working as you've got so much extra free time to fill
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
