I had a kogan dash cam when I went driving in Europe. Footage is nowhere near as epic as the scenery was irl (bad) but you can hear me saying things like "fkn hurry up m8" to the slow cars in front of me (good)
VWL engine swap day may not go ahead...for now.
Had a mechy pressure test the cooling system and check combustion chamber coolant...found a loose hose clamp that was letting air into the system. Engine now running cooler than ever thanks to the 1.3 bar cap (might put the old cap back on to get the temp up a bit when not doing track days).
However, there was a slight trace of oil in cooling system - potentially a slow head gasket leak or what he thinks could be an oil/water heat exchanger that can leak one into the other. May get an oil cooler to bypass this.
$100 later :)
Alternately:
Found out my "blown head gasket" is actually a cracked block... 7000kms after the build.
$12,000 to fix like last time and 6 months+
Also stock neo, $2500-3k.
mmmmmmmm...
Alternately:
mmmmmmmm...
Put an RB30 in it mate
Sell your stroker kit to recoup some funds
Never look back
There's a dash cam in the UK that is designed for motorsport too - pretty exxy at like $400 but it has 10hz GPS tracking / lap timer and heaps of other motorsport shit built into it; GoPro quality camera and sound / external mic input. Looked like a good all in one solution you could use on the street as an everyday dash cam too.
Falcon engine still going strong at 370rwkw 4 years on :D
get a miami engine and bolt it in brah
yeah, for 20k with a bunch of custom work
or you could LS swap it for a couple thou and throw a huge cam at it
Shhiiiiit Greg. I'd be done. If pulsar motor died again, I'd be done. Stock motor in, worry about other Shit later.
Daily the GTR? That's keen. Personally I'd be keeping kms and waiting for US import and club reg to start rising prices.
by the time you charge it would be the same money, but yeah get a LS and keep it N/A
or just sell the POS as is and move on
Second hand dashes can fix that
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
