yeah damn kennet for saving Victoria from being bankrupt.. thanks to who..... ham?
well that's still a debated topic however I beleive the most widely accepted theory is that it was mostly hedge funds that were delving into computer trading that precipitated a mass, uncontrolable liquidation when the stock values corrected...
Yeah he definitely loses by not choosing a wheel that in his opinion looks bad
His opinion is somewhat irrelevant - D1Rs drop panties and that's all there is to it
yeah cain - kirner did a stellar job.
"when Kennett and his new Treasurer, Alan Stockdale discovered that the outgoing government had left them with $2.2 billion budget deficit, a net public sector debt of $33 billion and budget sector debt of $16 billion"
labor for ya.
labor for ya.
Cain-Kirner did a fairly average job TBH and I am a fan of Kennet... although I do feel he could have been a bit less agressive in his privitisation/ sell-off strategy
However you do realise there was a world wide recession at the time no?
Hmm wheel decisions. Work Emotion CR Kai bronze (second hand), R34 GTR wheels (second hand) or MP37s (brand new with new tyres)? All should cost me between $1,500 - $2,000.
Here's a picture comparison:
Work Emotion:
http://farm8.staticflickr.com/7336/9408532537_64deef3197_b.jpg
MP37 (same style, not genuine TE37's)
http://www.daidegasforum.com/images/351/nissan-gtr34-nera-black.jpg
GTR wheels:
http://imgur.com/vDarLcx
Just don't go GTR (or D1R).
You want widebody plus spoiler etc, gtr wheels is just adding insult to injury. You'll be adding fuel to the fire that is 34gtr owner egos
And a neighbour just found Leesh's registration renewal in the wheelie bins...guess I know what happened to my registration renewal letter earlier this year.
Lock going on the mailbox now.
Yeah, couldn't care less what GTR owners think :P I could easily afford a GTR myself, it's not like they are a super exclusive club of expensive cars. Leaning towards the MP37 wheels, that way I can get a brand new set and new tyres to suit my car (plus the install and wheel balance is local).
see thats where youre wrong. They are the epitome of engineering and styling. They are the envy of every car enthusiast in existence.
Dont you read speedhunters??
  • Like 1
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
