yeah damn kennet for saving Victoria from being bankrupt.. thanks to who..... ham?
well that's still a debated topic however I beleive the most widely accepted theory is that it was mostly hedge funds that were delving into computer trading that precipitated a mass, uncontrolable liquidation when the stock values corrected...
Yeah he definitely loses by not choosing a wheel that in his opinion looks bad
His opinion is somewhat irrelevant - D1Rs drop panties and that's all there is to it
yeah cain - kirner did a stellar job.
"when Kennett and his new Treasurer, Alan Stockdale discovered that the outgoing government had left them with $2.2 billion budget deficit, a net public sector debt of $33 billion and budget sector debt of $16 billion"
labor for ya.
labor for ya.
Cain-Kirner did a fairly average job TBH and I am a fan of Kennet... although I do feel he could have been a bit less agressive in his privitisation/ sell-off strategy
However you do realise there was a world wide recession at the time no?
Hmm wheel decisions. Work Emotion CR Kai bronze (second hand), R34 GTR wheels (second hand) or MP37s (brand new with new tyres)? All should cost me between $1,500 - $2,000.
Here's a picture comparison:
Work Emotion:
http://farm8.staticflickr.com/7336/9408532537_64deef3197_b.jpg
MP37 (same style, not genuine TE37's)
http://www.daidegasforum.com/images/351/nissan-gtr34-nera-black.jpg
GTR wheels:
http://imgur.com/vDarLcx
Just don't go GTR (or D1R).
You want widebody plus spoiler etc, gtr wheels is just adding insult to injury. You'll be adding fuel to the fire that is 34gtr owner egos
And a neighbour just found Leesh's registration renewal in the wheelie bins...guess I know what happened to my registration renewal letter earlier this year.
Lock going on the mailbox now.
Yeah, couldn't care less what GTR owners think :P I could easily afford a GTR myself, it's not like they are a super exclusive club of expensive cars. Leaning towards the MP37 wheels, that way I can get a brand new set and new tyres to suit my car (plus the install and wheel balance is local).
see thats where youre wrong. They are the epitome of engineering and styling. They are the envy of every car enthusiast in existence.
Dont you read speedhunters??
  • Like 1
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
