OK property specialists....
Hoping to move forward with this land purchase in next few weeks.
what sort of questions should I be asking real estate agent prior to going to the bank?
WHat other stuff should I get ready prior to talking to the bank.
(other than the obvious, pay slips, car valuations, proof of deposit..)
Alvin, you still got your heart set on modifying the banana R34? Could upgrade to V35 or V36, faster out of the box just more expensive to modify (but much less attention too)
yes. modifying the banana. which reminds me, gotta come pick up those oil bits.
tomorrow sound good?
if you havent get a copy of the section 32 / contract of sale and get it checked by a conveyancer / lawyer other than that sort the bank and go from there.
if you want real estate help pm me and ill send you my number best chance to get me is text i only check in here occassionally
Edited by alr33x
Why wouldn't he have black? Black credit cards aren't special, they're just a ploy to suck people into higher rates and fees. You don't have to be on big money to get a black...
well an amex specifically you do.. min charge $250k per annum on it and invite only to have one.. i'd imagine they hand invites out with cmfeu membership packs.
thanks for that.
going to visit the real estate agent thursday, so any help is great
Katie is a nurse so her income will fluctuate. Most recent 2 payslips and FY14 group cert will likely be required given recent changes to regulations.
For good measure, 2 x payslips less than 60 days old (both) FY14 group cert and ITR and 3 months statements for any lending products you have with other institutions will probably cover most banks policy.
If the deposit is cash from under the mattress (i.e. not in a savings account) you might need to verify it.... feel free to pm me if needed
Can't see the bank caring about the cars though.
  • Like 1
Yeah the centurion card is a freaking joke. They say you need to spend $250k personal on another amex etc but I don't buy it. I reckon they will give one to anyone stupid enough to pay the rediculous fees. When I was working at Cosi soooooo many people had them.
have you spoken to the agent at all yet? if not i can call him first and try get you some info minus the bs.
via email yes, aiming for first F2F this week.
yeah assumed they want Group Certs, mine gone up since then so will provide last couple.
so not caring about assets owned more income, cool.
one of co workers got the offer, well over 200K, I'm only at 100-150 and none for me.
We really only care about assets we will register a charge over. A car is a depreciating asset and is pretty useless to us. It's only really ever used for direct financing where the asset (roughly) depreciates in line with debt amortisation.
In 99.9% of cases banks will just ask about this and not require any verification.
Group certs will show your yearly figures so any overtime/bonuses etc can be considered (although this is an absolute minefield now with APRA coming down on home lending)
Where I said FY14 above I meant FY15 (I deal with business financials all day and we are only just starting to see 15's now so I'm used to seeing 14's) but the 14's might as well be provided unless they are drastically worse.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
