I had the R34 when I bought this, so when Patrick suggested I buy it, I actually did.
Fuck me, was the editor on leave or did he just want everyone to see the real Mohsen?
The only thing more annoying than an iPhone fanboi... is an android fanboi...
If you genuinely think you NEED all the features and modifications available on an android and an iPhone won't cut it... You probably need to step back and have a good look at your life
  • Like 2
So true
lol like to see you use an iPhone to remotely ping your company server via vpn so you can find out how long it'll take them to receive your data packet containing encrypted binary for "iPhones are shit"
/averageandroiduser
something simple like making your own ringtones or message/alert tones and getting them to work properly on an iphone, its unnecessarily complex.
Want to grab photos/files/manage downloaded files/run a gameboy emulator and seamlessly play games with gameshark codes? so much more effort and essentially forced to have iTunes installed on every computer you plug it into.
Even bluetooth is just a PITA on iphone.
But what tipped me over the edge was requiring updates on the phone in order to sync/use iTunes. If you're phone is 1-2 models old and there is a new iOS version, the phone is basically f**ked. its running an OS that the phone can barely process on its own, let alone with 12GB of pics, videos, music, apps.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
