"Investigators believe the evidence supports that the accused aided and abetted the driver of the blue Holden ute in the death of his female passenger," he said.
I don't understand how to take this...so if there wasn't a passenger in the car, then this guy wouldn't be getting charged? Cause there's no mention of him aiding and abetting the death of the other driver. It seems from this statement like she is the innocent party involved and that's what all the fuss is about?
f**k sake it's retarded. Charge him with dangerous driving, but to hold him responsible for the crime...our legal system has gone full retard (American), needing a scapegoat to hold someone responsible when in some cases you just can't because the people responsible are dead or an act of nature.
And to oppose bail like he's an absolute danger to society lol, f**king terror suspects get bail. This guy puts his foot down a bit too often lol
While this is so clearly a political stunt designed not for the eyes of the PM but for the voting public.... It's still the right thing to do for these innocent children and I for one congratulate Dan on that, however... Is his grammar really THAT shit or is he trying to appeal to the less educated?
Heat (fkin Sundays)
Seven
Eve
Motel
QBH
Housexy
Frostbites
Odeon
Star Bar
Metro
Watermark (when Havana Brown was an unknown...or more of an unknown anyway)
Billboards (when Hamish wasn't DJing)
Evolution
ZOS (for Ric)
Trak
CQ
Bliss Lounge
Beach Hotel (more Sundays)
So many more I can't even remember
Off the top of my head...
After bar
Cage
Dome
Chevron
Subway
Mansion
Viper room
Saidys
Megabar
Tattoo (bubble)
Velour
Virus
Whisky Bar
CBD
Hifi bar
Velvet lounge
Redheads
2 floors up
Dream
Room
Saratoga
Soho
Q bar
Palace rear (monkey)
Capsule
Damn 680...forgot about that. And The Hawthorn
Oh wait...Cheers @ Casey's on Tuesdays! One of the diet mainstream places to pull off the RnB in one room, house in the other divides
  • Like 1
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
