We just work flexible hours at work. Come in whenever and leave whenever. As long as the job is done NAB are happy for us to do whatever we want. Funny thing is most of us end up working longer hours because of this.... Sneaky NAB lol.
When OT is on offer we just come in/work from home/go to a business banking centre and do what we want then tell them. Some people literally do 40+ hours of OT when it's on offer
That's the way a company should be; it's the single most efficient organisation plan and hardly any embrace it. Puts responsibility for productivity and output right into the hands of the employee.
other than our call center that how we work.
Surge tank if your worried about fuel starvation... Not needed unless running semi's on track I reckon (depending on tank design)
But knowing SAU, Mohsens car will catch fire at the fuel pump and Greg's will still starve from fuel when exiting his driveway
I went through 2 x 040's and a walbo 255 when I had a bad batch of fuel and didn't realise that was the cause of the deaths... grit in the tank for like 9 months....
Cleaned it, then went to a Walbro 460.... E85 compatible and it's been lovely ever since.
Walbro's are quieter and smaller in size than the Bosch's... go the Bosch and hard mount it poorly in the tank if you want the whine. because racecar.
Walbro 460.
wire it properly
overkill the shit out of the wiring
Good for the amount of KW on E85 you'd want before it becomes a laggy piece of shit
I think you should listen to Greg's suggestion, he sounds like he's on the right track
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
