guaranteed the owner won't be lying about the 10 second thing... he will genuinely beleive it would run 10's because it as a T-free turbos on it
probably has a T66 and a full MoTec system exhaust,
and maybe a stand alone fuel management system and enough NOS to blow us all up.
Fortescue Metals was a penny stock too...
I sold at 5.4, will buy back in lower as people panic sell. Staying for the long term but not watchin profit piss away in the mean time.
Market is incredibly sensitive to the smallest things - it was positive news and because of a typo or confusing explanation, or higher expectation...drops 10% and then people's stop loss orders set in like a domino effect...or people do what I did. Once it over sells / rats leave the ship it bounces back, hence bounced to 4.7 after touching as low as 4. I hope it goes/stays down for my buy back in, but hope it rises in general / long term. The fundamentals haven't changed for this one if you're in it for the long term - shitloads of oil in the ground, the oil hasn't gone anywhere, and the play has been derisked from 40% to a 60% chance of success - regardless of market sentiment it's a great long term investment that I'll be back in for, likely tomorrow.
It's being manipulated pretty hard - mum and dad investors dumping shares and losing out whilst institutional investors reverse their trucks up to the loading bay for cheap accumulation. The trade history was showing bots / high frequency trading hard at work. Nearly 10% of the company's value traded in one day, meaning there were buyers for all the sellers - and not traded into the hands of nervous private investors. Massive tree shake so the pro traders can get big IMO; that says it all about the company's future, but those selling won't be a part of it (actually better for the company long term with less emotional investors involved).
Being in a different time zone is f**king with me bad - can't daytrade this thing to make money, also going to be hard to pick when to buy back in.
Honestly Birds the stuff you wrote can be found in about every penny stock thread that as gone downhill on hotcopper
But as they say DYOR
IMO this stock will just go down and drift away until there is unexpected positive announcements
Hey i could be wrong and one day ill see you drive past in a Lamborghini
  • Like 2
It's true, however with this one the fundamentals are all there...the company is doing exactly what it set out to do and what started as a 25% chance of success has over time been upgraded to 60%, so not your usual pump and dump penny. They under promise and over deliver with announcements; any hype can be blamed solely on the market or third party manipulation. As I said, FMG started as a penny and one man's genius gave mum and dad investors Lambo money. I agree and think that there could be a bit more of a drop to it, particularly if the next announcements don't live up to hype. The next one to cause a massive jump would likely be a takeover / joint venture. But I've made plenty with 88E myself...I could sit it out and be happy with the win, but would rather lose it all than miss out on what this thing could do one day. First ride to you...
you guys are pissing money down the drain.
restaurants are where its at,
How many Michelin stars you got Moh?
Actually i got a friend opening up a restaurant in a few months
Ill need to remember to hit you up for equipment
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
