IT dude at work recommends sophos
What's the go with them?
I would like a nice stripped down anti virus with a basic as GUI, none of the extra tune up bullshit and toolbars and 5 different startup processes etc. AVG used to do that, until they sold out to freemiumware.
I used this on my Torrent box till I gave up on that.
https://www.avast.com/en-au/index
had a good run.
LOL...
yeah birds get on sophos AV, you can get it free for home use upto 10 devices just gotta make account etc. its good tho
we use it for small - medium sized businesses, pretty much perfect for that anyway (and home use)
Will give it a royal go
Though the best AV is to simply not give random applets disguised as updates permission to make changes to your computer. That's cryptonite for computer security.
could be worse...could have accepted a new root CA to your browser.
Spotted this from a few days back, interesting/scary read...
https://boris.in/blog/2016/the-bank-job/
Remind me again why people keep outsourcing projects like this?
as internal banks are usualy much worse..
http://www.bbc.com/news/technology-36110421
I could be ironic and comment it a Indian bank who they going to outsource to?
but the reality is all bank outsouce this work as it much faster cheaper.
what was done here was just way too cheap however, SSL v3 is bad, V2 is broken as such.
no SSL pinning.. well I've had that prob twice in past couple months, 1 where the company did SSL packet inspection so tried to decrypt our traffic. However as for this service we use client Client authentication the proxy did not have access to the private key so no traffic was accessed, PKI wins.
same today the Proxy was doing deep packet inspection, the product in question uses it's own Crypt not just https to avoid this. Proxy could not work out what happening and dropped packets.
pass though for our site and sorted.
in both cases the proxy is trying to complete a Man in the middle attack and was denied.
so just think, if you accessed banks at the office or similar the admins could take your details as they installed their own CA in the browser.
anyhow correct use of PKI and/or for that matter 2 factor authentication could fix all this.
Welcome to what I do for a living.
making the interweb secure.
LOL...
yep that's what I use on my home laptop :)
  • Like 1
Don't knock it until you drive one. The car was awesome. The sound and punch of the v6 was fun.
Was doing hill runs with a r34 gtr
1. It was just a question, Patrick.
2. If I confess that I have...would this validate the assumed criticism?
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
