Work site gets shut down until further notice... Have to hang around to do pointless tasks to appear busy. Urge to bail and watch nba at a bar rising.
Never even watched a game, but should be pretty exciting
Work cover only get involved if someone is injured. They suspect a (potentially) common defect. This is 1 week after we got the all clear from some random tests they did, it was always a crock of shit.
Most likely theyll line up a bunch of shipping containers and use that as a makeshift tunnel/blastwall so I can walk to a building in the yard. That'll take a few days. In the mean time I'm hoping Martin sends me his foxtel login details so we can stream the game.
Ahhhh the old shipping container tunnel trick...
http://www.heraldsun.com.au/news/opinion/andrew-bolt/the-case-for-voting-in-bill-shorten-as-prime-minister-and-removing-malcolm-turnbull/news-story/8260b3ac9ead7e2acd24a64f1e601192
LOL
It's amazing either how naive or genuinely stupid he is.
Reading that he clearly bases his entire political ideology on "leftists will ruin the country even when they are liberal party members" and that there is some form of correlation between how "right" someone is and their economic management abilities...
It's almost like he doesn't realise the country is run by a party, not a single person
Just heard an anti-Turnbull ad on the radio spoken by the ETU...had absolutely nothing to do with unions...or electricity for that matter.
Sex party gets my vote again; at least they stand for somethig tangible and desired
The liberal add with the fake tradie is freaking atrocious.... although no-one is going to overtake Bob Katter on bad adds this election
  • Like 1
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
